Attaching a stud to the balance bridge
Sorry about that! I sometimes forget politics are off-limits on WRT (which is a good thing!). I edited my post.
I would leave the politics aside. Now they fight for their freedom and potentially ours.
Many of us have tried this type of bezel remover but had no success at all. I've never tried this particular model though so I guess you should never say never. Anyway, there is a thread with a video showing how @Jon (a pro) removes bezels that I really recommend!
I have an old Poljot Stadium which has a date correction pusher. On mine the pusher itself has disappeared, so needs replacement. The inner tube of the pusher remains in place in place. I can pull the tube out by running a tap or easy-out into the tube but what can I use to press the new pusher in with? Anyone have a method of pushing pushers into place without the proper press tool?
By djwilliams37 · Posted
Not sure if this close up of the front helps. I have found several 8n24 movements available on Ebay for £22 and above. Is it difficult to replace the face and hands onto a new movement
