Boley WW lathe - what else do I need?
Hi all,
Just took delivery on a vintage Boley WW.  Motor is good, need to remount it on a better surface, but otherwise looks true and seems to work well.  Motor runs strong with foot pedal.  I know I need to WD-40 some of it since it's a little stiff, and probably have to take more of it apart for a good lubrication.  It came with matching tailstock, what I think is an index plate on the head, graver rest and a bunch of collets (all picutred).  I got a good deal because the seller packed it horribly and broke the base and acrylic holder, so I got a decent partial refund.  I have attached pictures below and I know I'll probably need a 3-jaw chuck and face plate, but what else?
It came with about 52 of the fixed size collets (at top in picture), 2 of the large open collets (not sure what they are called), one center punch, and 5 of the disc collets (far right).  I also assume the bottom item is a graver, although I will likely be ordering some new ones of different sizes/angles.
So what do all you lathe experts think?  Anything else I will need to start learning?  For the money, this seemed like a good starter point as far as equipment goes.
Edited by pent
pic rotate
You have most things you need to begin practising and turning simple parts free-hand. If you want to make winding stems, you will need a filing rest to file the square. That is a centre, not a punch.
The first thing would be to strip it, clean it and lubricate the bearings. You will need to keep adding a little fresh oil at frequent intervals, so get a supply before you start. Get some good lighting, magnification and measuring equipment too.
I use airline oil which is ISO 22 for my lathe and also for my oil stones and pretty much everything in between.
What you have there is exactly the same. Maybe cost a bit more as it is Mobil after all.
Here's a vid I made on disassembling an 8mm lathe headstock which might help. I did an assembly one as well
3 hours ago, oldhippy said:
Well it all depends what you want to do now you have a lathe I suggest you start by getting a complete set of chucks. You can never have to many gravers, I always used an arkansas stone to sharpen them.
3 and 4 jaw chucks? or chucks for drills? or both?  I'll definitely go graver shopping so I can learn which angles are best for different operations.
Get Archie Perkins' book Watchmaker's Lathe and How to Use It.  Read the book. Think about what you learn.  Experiment and practice.  In a few weeks of dedicated work you will know a lot more about lathes, how to maintain, and use them.  Seriously.  Do your homework.  You're not going to learn to use this fundamental machine tool by soliciting gratuitous advice on this forum to a few random questions.  My two cents. Best to you.
Great advice and already done!  I'm studying that and  watchmaker's and model engineer's lathe: A users manual as well.  BTW, T&T&T on youtube is an amazing watchmaker with the lathe so people can see some of the techniques close up.
    • Just picked this up earlier today. This find just about epitomizes vintage watch collecting for me and what really keeps me going. Hit 2 antique malls today and saw a couple of pieces at the first one but just nothing that I needed. At the second one saw a Accutron 218 but it was 20 minutes behind the actual time. These "malls" have numerous booths of a variety of sellers who likely go in once or twice a week. Considering that that watch should be within a couple of seconds a month, I figured it hadn't been phased so passed on that for now knowing it would need work to run correctly and the price tag. Then I found this Excelle in a display case. I never heard of the brand, but in was an auto and had a little heft. It turned out to be 40mm lug to lug, 35.3mm case width, and 12.3 mm thick. On the spiedel once size fits most flex band. At $10.80US with tax I immediately pulled the trigger with nothing to lose. Before pictures: I spent a nice 30 minutes taking it out of the case and running that through the ultra sonic replacing the crystal and gasket and recasing, but spent five minutes first getting it running close on the timegrapher. Had a new crystal already in stock. I probably could have sanbed and polished the old one, but for $3 there is nothing like a new acrylic that makes a watch pop, in my opinion. The caseback gasket was hardened and just glad it wasn't tar. Changed that as well. Here is the after Pic on a temp black strap while I decide on a leather or steel bracelet. An added bonus was doing some research and finding out the Elgin connection and the movement is a PUW 1563T which is German I am pretty sure and probably why it doesn't say Swiss made on the dial. This movement is supposed to have a hack feature and quickset date by pushing the crown. But neither of those complications seem to be working. Not sure if the stem is cut too short because there is no gap for the crown to move. Either way at some point will need to be serviced and check the keyless works to find out what is going on with the quickset and hack of the sweep second hand.
    • On the link that I posted, one of the watches has no crown and another has a crown that is not square to the case. Does a broken crown signify that the movement may be quite corroded, hence the stem has broken, and does the bent crown simply signify that the stem is bent? Unfortunately as the seller has a bid on the items, he is now reticent to prise the casebacks off in case he damages something. The seller did reply with this email though. Hi again Michael - brief descriptions; Oris x 2, dials and hands ok and they set ok and one I just wound and it has been running for a few of minutes as I write this response. Rocar, dial ok no crown. No name dial no good and can't pull crown out to set. Roma dial and hands ok, I think it is pin pallet movement. Unicorn, good dial and hands and plexiglass ok for age. All cases and plexiglasses show wear except as mentioned. I have no idea what movements are fitted or condition so please if you do consider bidding, please do so accordingly as I don't like to disappoint my customers - regards and thanks again for your interest - Jim
    • The incomplete Vertex DD is a new project to sort out.  The Seiko gen 1, is my favourite watch to wear and is my daily.
    • To be fair it was a beautiful 'bumper'.  But, there was some loose parts in the case.  Perhaps 'pig' was a bit excessive 😄.
