Hermle 130-020 "Bim-Bam", plate separation
Moose
Hello.
I am needing to re-bush the main and strike barrel arbor pivot holes on a Hermle 130-020 (know as "Big-Bam Strike" I think).  This is one of those with a vertical, free-sprung balance wheel. But this is my first Hermle movement and I need a little bit of guidance please.
The issue I have is that I can't see how to separate the rear plate from the front plate. I have removed all of the nuts and stripped the strike hammers and escapement away, as well as the plate holding the twin barrels in place. But how to get the back plate off and get access to the gear trains for re-bushing is currently a mystery to me.
Hopefully the photos are fairly self-explanatory, but the blacked posts seem to be riveted into the back plate, so that it won't come off. It may just be that they are on extremely tightly and need to be levered off, but I don't wish to damage anything, if it is something I have missed.
I hope someone can give me a little bit of a steer on this one.
Many thanks in advance.
Edited by Moose
Spelling
10 hours ago, watchweasol said:
Hi Moose I think the last one I did the posts unscrew releasing the plate.
watchweasol is correct. These movements are not made with strong brass or hard steel so the wear a lot and the springs are to strong for the metal a bad design. You will find how soft the brass is when you re-bush its like a knife going through butter.
Edited by oldhippy
I forgot to mention. From your description it sounds like it is a floating balance. Just clean it in Ronsonol lighter fluid then dry it with your bench blower. at each end of the balance where the wire goes through it should have a jewel, a tiny drop of oil at each end then move the balance up and down a few times so as to lube the wire, I always used a pocket watch oil, but Windels clock oil is fine for the job. Always use that oil for general clock repairs its the best and it is not expensive. Here is a photo of a floating balance I'm hoping it is something like this, if not can you post a photo of it.
Thanks for everyone’s help and tips.
Got it finished today and now just running it for 7 days or so, to gauge the rate and power reserve.
No issues to speak of; the wise words of Oldhippy regarding the softness of the brass plates saved me from being over-aggressive with the reamers!
Oldhippy, I did not lubricate the balance, but after reading your tip, I will go back and do it, as the amplitude seems a little low, although it it is keeping good time.
Edited by Moose
Thanks Oldhippy. I don't have a purpose made tool, so I had to do it by hand. I have done it a few times previously, but not on such a large hole (6.5mm with a 4mm pivot hole), or on such a soft plate!
I took the balance out again and re-cleaned it and used some clock oil on the jewels/wire, as you suggested.
I was considering a grease on the escape wheel teeth/pallet pins, such as Moebius 9415 (as per watch escape wheels). What do you think, would this be too light for this escapement?
Thanks, will do that.
G.
As a matter of interest and not having worked on this type of balance before, what is an acceptable balance amplitude?
I seem to be getting around 260 degrees - or thereabouts - based on a slo-mo video capture. I would regard that as OK given the age of the thing.
All complete now and sitting for a long term test till I give it back.
Cleaned and lubricated the balance jewels and also lubricated the pallet-pins and teeth.
Now seems to be achieving around 290 degrees amplitude (by eye) and keeping time to within a minute or two over 12 hours. The extended test will give a result over 7 days and I can make further adjustments as required.
Many thanks for all the suggestions for repairing and servicing this interesting (for me) movement.
Photo during re-assembly. New bushes fitted, partial reassembly. Just prior to the barrels being refitted. Then the strike hammers and escapement on the other side.
And a before pic.
Edited by Moose
I’m sure it will be better than than that over a longer period, as that was just for the first 12 hours. I had to put in a big adjustment on the balance adjuster to get it to come into reasonable time. I suspect that it had not really been adequately serviced for years, if at all, since it was assembled. So I have not yet had time to measure the going rate over an extended period, as it arrived non-working.
I have high hopes it will settle down well.
Edited by Moose
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
