Maintain power while winding (clock related)
Thanks Andy the 301 battery had leaked slightly which I cleaned out carefully. I used a 301 battery, but it never worked how do you get the back off if I need to as there is nothing to prise off or turn. See attached photo with battery compartment open.
There's a first time for everything, broken pivot on a barrel arbor, granted it looks quite small and feeble, in a plate jewel as well EB 8021N . Been running like that for a while looking at the wear on the plate. Typical all cleaned and ready for assembly, new balance staff fitted trued and poise checked. Check all the watch parts people before you start cleaning and find the irreparable repair first 🤨. Looks like me and the lathe will be getting reacquainted tonight 🤷♂️ -
By eccentric59 · Posted
It could be that the cap jewels are upside down. That could easily put enough pressure on the balance pivot to stop it. -
By Latetothegame · Posted
I don’t know if these pics will help to figure this out but it’s just a bit more information to consider. Here are pics of the crown, stem and case opening. Let me know what you think. That opening looks perfectly round. Thanks.
