DIY "Seitz" jeweled pivot gauge .......
In order to start learning my Jacot tool and select the right size bed, I wished for a Seitz jeweled pivot gauge.
Sadly, the prices asked for these gauges are astronomical. Currently on eBay from €350 and way upwards to over €500 !!
Wild West prices 😵
In my Seitz jewel-box I had a "complete" range of jewels 8,9,10,11,12,13,14,15,16,17,18 & 19 in the OD size of 110 and 20,22,24,26,28, 30 & 32 in the OD size of 120.
Marked 27x spots (1x1cm distance) on 10cmx10cm, 1mm thick copper-sheet and drilled them out with a 1mm drill.
The holes for the jewel sizes 8-19 were reamed to 109 and the other holes reamed to 119.
Cut the "to be jewel-gauge" at the size of 10x4cm, polished it and inserted the jewels;
Left the holes open for the "missing" jewels; 21, 23, 25, 27, 29 & 31 and there are two more slots empty for 33 & 34;
Whether I'll ever need these bigger sizes? They weren't in the Seitz jewel-box, perhaps for a reason? If I ever stumble over these sizes, I can insert them, the holes are already there. Those "missing" bigger sizes are also easy & safely to measure with a micrometer or gauge-caliper.
For now, I have a jeweled pivot-gauge with a full range from 8/100 to 20/100 and from 22/100 to 32/100 in steps of 2/100, I think enough for making a start on my Jacot-tool 🙂
Next, to finish this project off, is to find some small metal-stamps to number the jewel sizes.......
Edited by Endeavor
  • Like 11
If somebody, here in the EU, can help me on the missing sizes, preferably 120 in diameter, but slightly bigger are also no problem, I would be very interested.
Just in an envelop and I can pay with PayPal friends. Please PM me if you can help me out 😉
Edited by Endeavor
1 hour ago, praezis said:
However the gauge jewels have smaller hole tolerance than the public available ones, afaik.
It seems that you can't win 😬
The jewels I installed in my gauge are from a Seitz jewel-box. So, you are saying that the jewels installed in the official Seitz Jewel gauge do have smaller tolerances? If so, any idea by how much?
The whole, initial idea, was to have a gauge to safely determine a pivot size in order to select the correct bed of a Jacot tool runner.
Of course, my gauge has (hopefully) also to be able, in case of a broken jewel replacement, to select the correct jewel hole-size for a given pivot  .......... yes/no?
Edited by Endeavor
28 minutes ago, mikepilk said:
If you go in to production
Will notify you if I do 😉
Finally found a set of number stamps. Initially I couldn't find any on the German eBay until I typed the magic word "Schlagzahlensatz" in 🙂
3mm is hopefully a nice size ....
Edited by Endeavor
I'm also curious. What exactly does that mean? If a hole is specified to be 0.18 mm, whether on the Seitz jewel gauge or in the Seitz jewel box, its diameter is 0.18 mm, no (give or take a few microns which shouldn't have any significance, I guess )? 🤔
In my old Seitz catalog it says the jewels are accurate to 1/4 of 100th of a mm, or 0.0025. Not sure if that's +- or total; I recall seeing the same claim on one of the jewel assortments but not sure? I definitely have jewels in my stock (from other makers) with in-between sizes, like 0.095mm. I use the Seitz pivot straightener as a gage, and it's in 0.0025mm steps, so I would imagine those jewels are indeed held to a tighter tolerance. I think it's pretty standard practice to hold the jewel hole size to within 0.0025mm, it was 20 years ago but I visited the Robellaz jewel factory in Ste-Croix and remember being shocked how precise the jewels were- and also had a new respect for them!
Wild West prices 😵
Nice work endeavour, you have some good jewelling skills there
Exactly what I found and wondered about in my Seitz booklets.
There is much bla-bla about high quality and accuracy, but they avoid hard facts. Do they mean tolerance of +-0.0025mm? Would be funny, as their 0.0025 mm stepped gauges claim the same accuracy in the catalog 😀.
Only the preface in the 1944 book claims +-0.00012mm for the gauges. Some pages later, gauges, „accurate to 1/4 of 100th of a mm“.
Jewels: I can offer 23/140 and 25/140
Frank
To conclude this thread, here the end result.
Not as neat & slick as I had in mind and not as neat & slick as the "real-$$$-deal", but it will work. Two more jewels to be added (23 & 25), which are on their way, kindly donated by our valued WTR member @praezis
It's fun and educative making this usable tool. I hadn't done jeweling before and this has given me quite some practice. I also learned more about the Seitz jeweling tool and the reamers (https://www.watchrepairtalk.com/topic/26672-hole-shape-when-using-a-seitz-jewel-setting-tool-reamer/)
Sadly for the few, it won't be taken into production. Inspirational only 😉
Oh yes, I managed to screw up the stamping of the numbers, but which other number better to pick than number "13" ? 🤣
Edited by Endeavor
Not sure whether to like or laugh.  Hehe.
Haha on purpose or spooky ?
…copied in quantity they could be plates for the buttons in very small elevators?
    • You're right Rich, throwing money at something that is practically worthless. I've had i happen a few times, its  disappointing, but a lesson learned in checking everything out before you put in too much effort. I'm still tempted to look through a load of balances and wheels i have to see whats doable with the genuine staffs, I'm thinking the  wheel that it came with is not genuine, it's had it weight completely hacked down.
    • Ok thanks  it was just the brass cover next to the previous 3 keyless parts. Normally i wouldn't have expected that to be used to identify,  but I've searched American,  German and French part catalogs and coming up with nothing for the set lever,set spring and  yoke. I will have another look later today. There is another way but you would have to measure the stem very accurately.
    • The diameter of the dial side is 40mm, and the other side 36,5mm. Here is another picture
    • The chronometer on the dial might just be a brand name, looking back yes i was mislead by the mention of Remontoir inside the case. Still not sure why it says Ancre Remontoir which translates to anchor winder, i imagine that means lever winder which still suggests to me 2 winding springs. I'm sure i have that same watch with chronometer on the dial ,I've never ventured inside it. My missus looks after 90% of my watches , so i will get hold of that one and have a look inside. Haha no not a remontoire, looks very basic.  Good to see the keyless works, can you measure the plate size to cut down on the search for them. Can you lay out that brass bridge cover as well please next to the other 3 pieces.
    • That's true. It is not a chronometer. As a matter of fact, I got it with another timepiece which is e real one, and only that (not a watch). I add a few pictures of my Chronometer / watch. no indication of a brand ...
