Swap Meet Find...
Hi All ,
I went to the Swap meet at Aloha stadium today and found this Seiko  6117-6409 World Timer made in Feb. 1972 . It's running and keeping time so far . The inner bezel with the cities rotates as it should and the GMT hand is also working . It has a Linen Dial and the watch is in good overall shape .
The only flaw I can see is a scratch in the acrylic crystal that I can easily clean up but I made a bid on a new Seiko crystal . It has a generic expanding watchband , but I may get a dark blue leather or blue suede watch band . I'll look around for that and see what suits the watch ............I was able to pick it up for under $50 .
It's almost like you live in a bubble protected against the costs all the rest of us are subject to, are you sure it's not called Eden. Hawaii is definitely going on my holiday list !
Another great purchase !
Cheers,
Vic
Thank You ,
 I can assure you that not all of my purchases are a pot of gold at the end of the rainbow .  Just in the last week I received an Accutron that was advertised as a non runner . The outside looked good and I thought that maybe all it needed was a stem and crown and a battery .When I opened it  , it was a pile of rust .
  But the Seiko in this post is a nice one and I am always on the lookout for a nice watch at a value .
    • I'm just about to clean the parts of a Cal 684 which has a similar Winding Gear (#1464). I plan to clean it in my usual way (ultrasonic with Elma solutions) then dip in Lubeta V105. As for Epilame. The only parts I'll be treating are cap/pallet jewels and escapement wheel. I'm not splashing my precious fluids all over the place !
    • Yes it sounds as if the gut has fouled up. If the clock is not level that can cause the gut not to wind onto the barrel . You need to take it out of its case and post some photos. The type of key for these clocks are crank keys.
    • This guy unites the two reverse wheels in the usual system of winding movement. Do not take it apart, thow takin it apart is possible. You can get lost the small ratchets inside. I wouod use pure petrol to clean it ahd will rotate for some time the wheels when holding the pinion untill the guy is diped in the petrol. Then, after epilaming (if any aplied), I would use some Moebius 8000 solved in pure petrol and put a drop on the wheel, then will blow with air and let the petrol dry. This is old recepy not from Omega manuals where I have no idea what is the procedure.
    • This is to prevent the stone on the other side from breaking when canon is pressed. You can put the canon before assembling the movement, but this is if the 3th wheel when in place will not prevent the other wheels to get in place. The other way is to assemble the train and then to put the movement on something that the pivot tip will lay on and thus the pinion will not press the stone when canon is installed.
    • My experience with this Vertex is to unscrew the ring towards the back, with a screwdriver on the slot.  The Crystal can then be pushed back.
