When watching a timegrapher, what causes the swings with the rate?  For example, in this capture, you can see it starts out at -22 then -4 then +4, the -2, then -24.  My question is what is the cause?
I'm thinking it has to do with the balance wheel and possibly the pallet fork, but not sure exactly what it may be.  I'm hoping someone more knowledgeable can help me understand the theory of what I am seeing in the image.  This is coming off of a 1970s Caravelle 11DP 7 jewel movement.
The Bulova 11DP is a licensed version of the Citizen 0241/1802 series of movements, much like the HMT 0231 which coincidentally I've just been looking at as it was in the HMT Slim I posted about earlier today
As you can see, they look remarkably similar, with only a slight variation in the plate shapes. Some of the older HMTs have almost identical plates to your Bulova.
My suspicion from the time grapher pattern is that the instability might be related to the escape wheel. Did you remember put a tiny amount of oil on the palette jewel faces?
How clean is the escape wheel. Can you examine it under a microscope to see if it looks to be running square and true, and not worn or dirty.
I vaguely remember reading somewhere that the HMT version is rated as +/- 20 sec per day, but I've generally managed to do slightly better than that, even with some of the very rough and ready, well worn specimens I've looked at. The fixed stud regulator is a little bit of a pain, as it obviously makes getting the beat error down somewhat of a faff.
Parts from the HMT *should* probably fit on the 11DP. I did cobble together a Citizen version with some HMT parts at one stage. Also there are several variants of the HMT version, and all of the parts seem to be interchangeable between those. I make no claims for this being a good idea, but if you are struggling to find parts, that might be one avenue to explore.
Edited by AndyHull
it would be helpful to have the background history of the watch.. In other words new watch that hasn't been cleaned yet or have you service this watch?
Expand
This was a difficult one to get oil on the palette jewel's due to the way the wheels practically cover up the entry stone.  Possibly I didn't do as good of a job as I had thought.
Expand
It's clean, but I will take a look at if it is worn.  I did not even look at that.
  On 5/1/2023 at 11:24 PM, HectorLooi said:
Try running it "bare bones
Expand
The timegrapher results were in the bare bones state.
Expand
The watch had just been cleaned.  Whoever had the watch previously must have serviced it as it was overly oily.  I cleaned the entire movement except the mainspring.  I also did not take the balance jewels out and clean those, as I tend to have issues with that, so I really should do that as well.
Okay, so I just looked at the escape wheel and I think I see an issue.  The one end looks a bit mangled... I hadn't noticed this before and when I was checking end play I must have missed it.  Looks like I need a donor movement now...
Also, here is what the mainspring looks like.  Really dirty, so that may either mean I need to clean and lubricate it, OR a new mainspring.  Take a look at the top of the second picture though.... it looks like the bridle engages into the barrel on this one... this is only the second mainspring I have looked at, and yes I know it would help if I took it out and looked at it, but when inspecting it under the microscope, this is what I saw and it caught my attention.
Lastly, looking at this, am I correct that this is a right hand wind mainspring?  I believe I read someplace that when you look at the mainspring in the barrel, if the end of it (part that connects to the arbor) when placed in the 12 o'clock position... if that points to the right, then it is a right hand movement.
Expand
I was kinda hoping you're going to say this is the incoming watch because that's what it looks like.
Expand
the weird wandering a fact could be caused by magnetism but more likely is uneven power. Like what happens if you didn't clean the mainspring and it's sticky. Basically all the rest the work he did is somewhat worthless if your source of power just isn't functional
then the random dots or the wandering dots themselves a lot of times as caused by bad lubrication on the escapement or things related to the escapement.
Expand
yes really dirty is really bad. As you need the practice of working with mainspring is I would go ahead and take it out and try to clean it then put it back in again and see what it does for your timing machine results.
then right-handed versus left-handed mainsprings? 90 some percent of the time your mainspring will be right-handed. The most typical exceptions of not being right-handed are full plate American pocket watches and Seiko watches. There's a few others but they're usually right-handed. In other words it means when your winding them into the winder your turning to the right or clockwise.
Expand
I've attached an image to add to our confusion. So if you think about the mainspring winder as being off the set of your barrel so you're going to turn the handle clockwise or to the right wind it into the winder stick the winder into the barrel and push it out and when it's pushed out it should be in the opposite direction to catch. So you look at the image below the mainspring itself in the barrel is winding counterclockwise. Then the picture you have of your mainspring is winding clockwise in the barrel. So it appears to be that citizen copied Seiko and that's a left-handed  Barrel which is weird there must be something about the gear train that we can't see. It be interestingly take the watch apart again if you do is to get some pictures of the watch.
oh a muscle attaching another image this is a mainspring in the ring it would normally come in. They colorcode the rings sometimes so you can  tell easily which side is out so you're looking at the ring exactly the way it should look on top of a right-handed barrel and does it look the same as yours spring? Sometimes I wonder if I'm having dyslexia moment getting things backwards which is why we give you the images you can decide for yourself but since this is really a Japanese watch there is what they did although?
oh and the other clue you have done all of this is if the watches fully wound up you should have more than 204° of amplitude. Plus as a guess if you rotated to a crown position like crown down it will probably drop way below 200° and that's also an indication he just don't have enough power. Like a watch that's never been serviced which is why asked the original question as this looks more like a incoming watches needing to be serviced in a watch that's been serviced
so when I press a new mainspring in, I keep the color coded side up (facing me) when I insert the spring?
Also, to clean the mainspring, how do you recommend I do that?  I just use these small glass jars that hold only about 2oz so that won't work for the springs.  Wipe them down by hand?
Edited by kd8tzc
Expand
yes on a normal right-handed watch they just shove in. It's why most people don't play with the mainsprings they just buy a new ones they can just shove it in. But look at the direction that your arbor rotates in to wind the mainspring it's rotating anticlockwise direction. Now look at the spring in its ring it's going in a counterclockwise direction. That means you just flip the ring upside down the correspond to the direction that it needs to wind in and everything will be fine. But I want you look at this because I might be having a weird dyslexia moment and getting this all backwards which is why gave all the pictures for you to study
This whole left hand vs right hand thing gets me all messed up.  I never know how I should attach it to the winding arbor as don't you need to flip it or something.  I thought I saw on some video a way that the mainspring should look when you are winding.  I think it had something to do with the bridle but I can't recall... I should have taken notes as I can recall where I saw this now.  Maybe it was one of Mark's videos here on the forums learning videos.
Expand
 the left and right really has to do with the handle of the main spring Winder. In other words are you going to turn to the right clockwise or you can turn to the left counterclockwise.
Then suppose the mainspring was missing all you have is the watch in the barrel oh dear what would you do we can't look at what was there before how would you know which way to put it in? Well that's easy you take your barrel without the arbor and centered in the watch how does it go in the watch then you put the arbor in the barrel to see how it goes. Then you put the arbor the barrel so you can see the arbor in the barrel you see which way it winds the mainspring. so the case of the brand-new mainspring in its ring like an image you can compare and it's easy to see which direction it takes to wind it.
Now where things get really confusing is when your winding it into the mainspring winder it's going the exact opposite way of the barrel because when you shove it in it gets developmentally challenging for me at times I just remember I'm always turning the handle to the right unless it's in 18 size full plate watch and then it gets turned to the left because they're left-handedthis is why you find the colored rings on one side with new mainspring is because 99% of the time they go in one direction.
Expand
This used to catch me out as well when I started. Do yourself a little drawing of which way round the spring coils in the barrel before you take it out. Also double check that this is correct by looking at the  direction of the arbor hook. Then instead of trying to look in the winder end to see how it should go, site down from the top of the winder the push button end, imagine seeing through the winder as if it were invisible. From that angle of sight the direction of the spring's coils will match.  Hope that makes sense.
Edited by Neverenoughwatches
Expand
Here is how I think about it. I look at the mainspring in the barrel and look which way the spring runs, from the hole end to the bridle end. In the 11DP as you showed it goes counter clockwise (CCW) if you follow it from the hole end to the bridle. That requires a left hand winder. If it were to run clockwise  it requires a right hand winder. So:
CW = right hand winder
CCW = left hand winder
Then when you want to wind it into the winder, place the spring on your bench so that it is in the same orientation as it was in the barrel (CCW). Now lift the spring up, keeping it in the CCW orientation and slide the winding arbor into the spring from UNDERNEATH. It doesn't matter if it's a right handed or left handed, if you put your spring on your bench in the same orientation it is in the barrel and then slip the arbor into the spring from underneath you will always be OK. Here it is illustrated on a CCW mainspring like in the 11DP. The spring was laid on the bench in the CCW orientation and then I slid the winder in from beneath.
I just looked at an 11DP and it takes a left hand size 6 winder.
Edited by GuyMontag
Expand
Thank you... that helps me tremendously as I was struggling to figure out how to lay the spring and then put it on the winder.
Expand
Couldn't I also just wind the watch (assuming it is not an automatic) and see if the barrel turns CW or CCW?
Expand
Great advice with the drawing... I actually take a picture, but I just did two drawing of CW and CCW in my notebook and labeled them Left and Right so I know what I am looking at now.
as far as using the mainspring winders goes is pretty simple unless you using a vintage set. Like my pocket watch Winder will go in either direction as it's just a pin sticking up. But if you look at the modern Winder the way the hook is designed it will only go in one direction I'm not saying you can't but I would say it's it's only going to go in one direction.
a place for you have any confusion is something like this watch or vintage 18 size American pocket watches or Seiko automatic watches typically 90+ percent of the spring is all go in one direction and the right-handed winder will let you get there.
Expand
yes that would also work but you have to put together enough of the watch to do that but yes that works anything to see the direction but as I said 90 some percent will only go in one direction. Which is why when I'm doing 18 size pocket watches I really have to pay attention and go the other direction otherwise I'm annoyed with what just happened.
Oh then there is the other strange little thing with your watch notice the screws on the ratchet wheel and Crown will notice the extra lines those are to tell you that both of them are left-handed screws. The crown wheel tends to be left-handed most of the time because otherwise when your winding it it would unwind the screw and fall so this way of the screws does anything ill typed itself up. But typically the ratchet wheel screw is always a standard screw except in this case it's left-handed because it's going on a square arbor it really doesn't matter but I wonder if they're trying to tell us something?
Expand
The key part of the advice is to sight down from the top of the  winder, as though you are about to push the spring out into the barrel. The orientation of the spring coils is the same as looking at the barrel. When you look at the spring once its wound into the spring winder its reversed you are looking at the bottom of the spring once its in the barrel. I may not be explaining this very well, its easier to show what i mean.
Expand
The watch itself shows which direction winds it up, and thats all you need to figure out the rest.
Okay, so still struggling with the winder on the 11DP.  I'm using the left handed winder, and I can get it to hook onto the arbor, I get everything all the parts of the winder together, I see the mainspring slowly start to go into the winder, but then I feel it slip after about the second turn.  This is with a mainspring that came with the watch (waiting for the replacement to come in the mail) so what should/could I do to prevent this from happening?
As a side note, I tried winding a newer spring from one of my "parts" Seagul ETA 6497 clone on the same winder.  Granted, it needs a bigger winder, but I can latch it and get about 80 - 85% of the mainspring in the winder.  Possibly I am doing something wrong with the older mainsprings.
I have the #6 Bergeon... so I believe that is 9.8mm.  I believe I saw someplace that it should be using a #11, which is 15mm, but it works on the #6 arbor.  Now how do I get the 11Dp mainspring to work on the #6?
That's the correct sized winder. If it's slipping off the hook on the winder I would confirm:
1. The inner coil of the mainspring is tight to the arbor when you insert the arbor.
2. Confirm the the hook on the winder is engaging the hole on the mainspring. I like to look under the microscope.
3. Confirm you are winding in the correct direction.
Other than that I can't think of why the spring wouldn't wind into the winder.
I'll try and get a picture and you can all critique.  Possibly I think I am doing it right, but you will spot a mistake.
Expand
the problem with modern mainsprings are made to very exacting specifications. The problem with the mainspring winders are there may to sizes which do not necessarily correspond to the size of the mainspring. In particular the inter-coil just may not catch because they're not the right size. This is where a lot of time you have to do mixing and matching of the handles to see if you find one that fits. Or if you have the older set that has the more aggressive look sometimes one of those might work. or sometimes appear have enough tools an entirely different set may be needed.
Then how exacting of the specifications? You'll notice they have the standard set with numbers on the handles corresponding the sizes but they also make sense that correspond to exact watch calibers like the 6497. Which starts to suggest that the sizing is really really critical if you have to have a specific winder for a specific caliber. As opposed to just saying use number whatever because of be close enough.
Expand
If the inner coil is wound tight enough around the arbor then probably a problem with the latching of the arbor hook onto the mainspring's winding slot.  Is the hook on the arbor ok, Undamaged ? Is the portion of the mainspring's slot that catches the hook ok and Undamaged?  Either or both of these can receive damage if roughly unhooked especially when a tool is used to help unhook the spring after winding. Check the inside edge of the mainspring's slot.
Expand
How would increasing the size of the mainspring's slot be. There are old pliers designed do this but maybe not cut into a modern alloy spring.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
