ETA 2541 endshake problem
Hi,
I have been working on an old inexpensive watch fitted with the 2541 movement, to learn the features of this ubiquitous design.
The reassembly went fine, but the watch keeps stopping. Besides an issue with the autowinder reverser wheels (remedied), I determined that the fourth (seconds) wheel has too much endshake. As such, it is coming into contact with the third wheel, and stopping the watch.
The endshake issue would appear to be on the dial side (I don’t see how adjusting the jewel on the train bridge will help, as that will simply push the wheel down on to the third wheel. I can’t see how the dial side tube (the centre seconds pinion goes through it) can be adjusted.
Any thoughts or suggestions would be welcome. I am wondering if a NOS replacement fourth wheel is the way to go. Perhaps there is wear on the ‘shoulder’ of the centre seconds pinion? Or do I need to replace the whole mainplate?
Many thanks.
Bill
If the end-shake of the 4th wheel isn't too bad you could possibly instead move the 3rd wheel a bit away from the fourth wheel. If the end-shake of the 3rd wheel is already good you would have to adjust both jewels equally.
As a rule of thumb, the end-shake for small pivots should be approximately half the diameter of the pivot and about 1/3 of the diameter for large pivots .
Many thanks. I found a parts list for the 2450 series of movements and spotted the centre seconds pipe, which is actually detachable and friction fit. I think the similar arrangement on some old Seiko movements are riveted in. I managed to get the old one out with a pin vice and the new one in with a jewelling tool. So far everything is running well again.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
    • I was spitting out flowers and leaves for 10 minutes,  fortunately 3  people saw it and promptly whipped out their phones to film the quick " nothing to see here " recovery  🤣🤣
