Pressure testing non screw down crowns
I have a new pressure test machine to test my watches water-proof(ness) and have seen several videos on testing watches and I am confident that I can perform a test on the types of watches with a screw down crown. However I have other watches (non-diver) which are 'water resistant' but they have a regular push down crown which I wold like to test. Does anyone have any tips on how I keep the stem/crown seated in place during the pressure testing process, without a movement in the watch case to hold them in position the stem/crown could simply fall out. during the set up or shoot out during the de-pressurisation phase of the test. I was thinking of using some tape just to physically hold the stem/crown in position mimicking the function of the key-less works, but wanted to know if anyone had any 'best practices' or other ideas?
When you have a hammer, not everything is a nail.
"Water resistant" means that you could, with some luck, walk with your watch in a slight drizzle. Not for under the shower nor swimming. I've heard plenty of stories were so called "water-proof" up with low ratings watches (new) got "flooded" with water after a bicycle tour in the rain.
Has your "water resistant"-watch a rating at all? If not, to which pressure do you like to test that watch? And, once you break the seal, the test is void.
Edited by Endeavor
Which machine and maybe a picture?
Isn't the crown supposed to have a gasket if it's a water resistant watch? If it has a gasket it seems like it would probably stay in place.
My belief of waterproof and water resistance is that the waterproof is just that and is build withstand the pressure of diving in water to given depths. If you exceed the depths as stated you risk blowing the seals and suffering damage. Water resistance basically that it ok in the occasional rain shower and an accidental quick dunk but not prolonged imersion. Even a watch without a screw down crown with a gasket is dependant for its water resistance on the condition of the seals. Just because it says water resistance it might not be .  In either case as stated it’s all down to the condition and age of the seals.
My understanding is that the WR is measured static water column. All bets are off if the water is moving or the watch is moving through the water column, realistically it would more likely be both are dynamically changing. I think PADI certified dive watches are rated to 200m water resistance, I don’t believe PADI goes beyond 30m, at least for recreational divers.
Tom
On paper water resistant testing seems pretty straightforward. But as you noted other things will affect this because a diving watch is meant to have pressure to hold everything together and keep it sealed. Thing about like a cork going into a bottle more pressure the harder you push the cork the better the seal.
Where things get really bad is you wash your hands there's no pressure and as you commented moving water has a habit of getting into places rather than static water. Or you wash your hands with hot water a heat up your watch the air expands and because there's no pressure on the watch other than just the gasket which of its old is probably disintegrated anyway then when the air cools down it pulls the moisture pass the gaskets.
I think I saw Seiko once had a brochure on what the meaning of the various water pressures are on a watch as to whether you can dive into a pool or go to see diving or even wash her hands but like you said washing hands is worse than diving. Although it's not the worst thing of all to do.
The worst thing if you want to destroy a watch including a Rolex is being a farmer. I once visited a watchmaker in Idaho who told an interesting story. A lot of the farmers in Idaho use siphoning to get their water onto the field so when you're driving along the fields you'll see all these half round pieces of aluminum pipe and ponder what therefore unless you actually know. So what they'll do is ill fill up a ditch next to the field with water which is typically cold and then they will stick the half from pipe CN and flip them over and they will siphon the water out into the field. The problem is Idaho is typically hot at least where I was in Idaho and the farmers gravy hot sweating because he's working hard and is shiny Rolex is going to get hot in the sun and then it's going get drenched into the cold water. Depending on how big the field is is going to be hot cold hot cold For quite some time and according to the watchmaker I talked to he didn't care who is watch it was diver whatever they would disintegrate. But you look at the water resistance they're not based on that sort of thing they're based on water pressure solid pressure like a column of water not real-world situation of the water could be hot or cold words moving or its oh then there's the other thing
it could have other influences like hand creams or are the sanitizing creams that we have now a lot of those are not good for the caskets. Yes I work in a shop with a change a lot of batteries and they dry pressure check all the watches and they complain about the lotion that's under the back how dirty the backs can yet the dirty the bands can get it's amazing how dirty your metal band would get the time.
Thanks you all for the comments above, my intention is just to see if the gaskets I install on refurbished (non-diver) watches are installed and functioning correctly. I assumed a simple low pressure test (3 bar?) would give this confidence. I appreciate that there are a lot of factors in the gaskets holding in the real world, but if they are not installed correctly by me from day 1 then they have no chance of working, so I want to be sure I give them the best chance possible - hence the pressure test.
Maybe there is a better way to get the assurance over and above a visual check that everything looks to be installed and working correctly when it leaves my desk, any experience or recommendations greatly appreciated.
Water resistance ratingSuitabilityRemarks
Water Resistant 3 atm or 30 mSuitable for everyday use. Splash/rain resistant.Not suitable for showering, bathing, swimming, snorkeling, water related work, fishing, and diving.
Water Resistant 5 atm or 50 mSuitable for everyday use, showering, bathing, shallow-water swimming, snorkeling, water related work, fishing. Splash/rain resistant.[6][better source needed][7]Not suitable for diving.
Water Resistant 10 atm or 100 mSuitable for recreational surfing, swimming, snorkeling, sailing and water sports.Not suitable for diving.
Water Resistant 20 atm or 200 mSuitable for professional marine activity, serious surface water sports and skin diving.Suitable for skin diving.
Diver's 100 mMinimum ISO standard (ISO 6425) for scuba diving at depths not suitable for saturation diving.Diver's 100 m and 150 m watches are generally old(er) watches.
Diver's 200 m or 300 mSuitable for scuba diving at depths not suitable for saturation diving.Typical ratings for contemporary diver's watches.
Diver's 300+ m for mixed-gas divingSuitable for saturation diving (helium enriched environment).Watches designed for mixed-gas diving will have the DIVER'S WATCH xxx M FOR MIXED-GAS DIVING additional marking to point this out.
Here is some text about WR resistance, hope this helps. WR for non professional dive watches is defined by ISO 22810:2010, probably very dry reading if you can get your hands on it 🤪. It does however lay out testing and definitions that would probably help, I’ll see if I can find a copy.
Tom
Found it!
Tom
ISO-22810-2010.pdf
    • I was pleased to pick up a selection of some tools on ebay (v cheap 🤣), and they've just arrived,  I've been looking for a crystal press for a while, and this one is ideal But in the selection is this thing - what is it for?  (it's about 3" long) Something to do with stem tubes?
    • You'll have to strip it back anyway.
    • I think I've heard that more than from just Alex. That doesn't make it right though, but I'm convinced i saw some literature diagram explaining why to do that. There must be good info here in the archives, I'll have to have a dig around.
    • That will mean dismantling the gear train, which with 5 pivots to align was a pain. Probably going to have to though. I'm convinced it's something to do with the great wheel.
    • As far as I know, the only time an epilame treatment has potential drawbacks is when something is rubbing on the treated part w/o lubrication in between creating abrasive dust. That is, I don't believe in the method of "running the watch to make a groove through it first in the pallet stones where the lubrication is then placed". So, I think the rule would be; do not epilame treat parts where rubbing is going on without lubrication. Other than that I don't think we have anything to worry about. That said, I'm not an expert, and I'm always happy to learn more. Has any other repairer than Alex suggested or explained the "making-a-groove" method? My impression is that it's just something he constructed in his mind. I have not perceived it as a generally practiced method. Again, I could be wrong!
