Polishing Setup
DJT2
Hi guys, I've been looking for ages at getting a Polishing machine & I've just come across this. I'm probably opening a can of worms by giving the link as I'm sure others may jump all over it. So please, please don't bid. However, I'd love your opinions. http://pages.ebay.com/link/?nav=item.view&id=252034854605&globalID=EBAY-GB&alt=web
Sent from my GT-I9505 using Tapatalk
It's the real deal if you are going to be doing heavy duty case refinishing on a regular basis. You could do a lot of good work, and damage, very quickly with it.
I certainly won't be bidding, as I do all my case refinishing by hand, and just the occasional touch with a Dremel.
A Polishing machine is nice, and works well on really gold watch cases and jewellery. For refinshing watches i would recommend getting a Foredom TX300 Jewelers Kit, http://www.ebay.com/itm/Foredom-TX-300-Hi-Torque-Flex-Shaft-Kit-/330883038562?pt=LH_DefaultDomain_0&hash=item4d0a2a7d62
With this you can do nearly anything you would ever need for refinshing or repairing watch cases, incudling adding satin finsh, sanding out any straches, drilling, riveting watch pins and hand polishing.
+1
+1
Hi Geo & Frenchie, I realise you guys apprehension to recommending such an industrial commercial machine to a complete novice like myself. After all, I have never ever touched a Polishing wheel in my life. I understand if not used correctly I could cause some real damage, but on the flipside.. With practice, practice, practice & alot of respect for the machinery. Intime (over yrs) it would become a real kick **BLEEP** skill to learn.
Although, I'd love learn all the aspects of watch horology. Including, lathes & machining parts etc. But I have to be realistic. I live in nice apartment over looking the Estuary in Lytham (no garage) . My kind wife has given me a mancave room & she would not appreciate me turning it into a metal shop. Therefore, I'll have to curtail my dreams/ aspirations & fucus on the areas of this hobby that would give me the most satisfaction & overtime I could become quite proficient at. Hey, it may take me the rest of my life to produce a professionally refinished watch case. But at least I'll die happy & trying
That's a nice bit of kit, but you would have to be a serious user for it to make sense. £270 is a lot for a machine you may only use infrequently.
The options suggested by the other guys makes more sense to me and it wouldn't hog as much space in your man cave.
This is my setup for machine polishing, and I rarely use the big one for watches.
post-1141-0-88543700-1437789472_thumb.jp
The polishing machine I had was similar to this old boy. As long as you have the right compounds and polishing brushes and you understand what there for and you take your time (you don't need to use it flat out) you should be alright. There are a few polishing tutorials on youtube that you might like to look at. This is just my opinion but what you have your eye on I think it is far too big for watch case work.
Thanks guys for comments, I realise it's a bit of overkill. My problem is that without a garage or outdoor space I'm stuck to converting a room in our apartment for my man cave. Therefore, what ever I chose needs to have its own ventilation system.
    • I'm currently 3D printing a new basket and trays for my Pearl machine - I printed one last week in PETG material and it worked well at first. I had taken a calibration cube and soaked it in old cleaning fluid for 8 weeks and then measured it, and there was no discernable swelling or shrinkage and the cube seemed mechanically intact. All went well after the print and then onto the drying..... that's when things went awry. The heat was more than I was expecting and the basket and individual trays warped and deformed. I am now trying to print from nylon - which is extremely difficult to print with, my third attempt is chugging away now while I am at work - hopefully I don't go home to a ball of wool like last time!
    • It is possible to true the pearl basket to run better takes a good hour of filing though.
    • Yes, the general pat is this. On my diagram the points where the springs rises and levels are marked with red circles. This is only to show on all pictures (the ones that doesn't show this points as they are seen only from aside, not from above) where this points are. On You pictures, the pont where the spring rises is not marked. The point where it levels is marked with A. The point B is where the change in radius should start, but there is sharp bend there which should not be that sharp.
    • I agree, very minimalist dial,  but then the diamond. The 1973 R has a black dial and gold case and is similar in layout. But on the MyBulova site there really is nothing else like it...
    • This is such an odd Bulova. Off of the top of my head the only other mechanical Bulova that I can think of that has the 'Bulova' logo as an hour marker is the Golden Clipper 'J' (there must be others), one of my favorite dials. And then it has a solitary diamond, which is not unusual with Bulova, but paired with the 'Bulova' hour marker, that only leaves two quarter hour markers, and I can't think of another Bulova that has only two hour markers like that. You do you Bulova, no conformity here!
