Introduction
AlecJ
Hello all. I am new to this form. I stumbled upon it through the fantastic YouTube videos on the Watch Repair Talk channel.
I am a Clinical Laboratory Scientist by day and wannabe watchmaker by night. Actually I could never aspire to the heights and skills of Mark, but maybe with some practice and time I might become decent enough. My current occupation I believe has direct application to watch repair/making. I am quite comfortable working with very small samples and magnification.
I have been collecting watches for some time now and have recently taken to learning the insides. I have been reading and learning as much as possible, and collecting basic tools. I plan to do the Nicholas Hacko guide to tear down and rebuild a Seiko 7s26c very soon. I have also been collecting old cheap watches to learn on after the Seiko adventure.
I am certain I will have many questions as I do already. If I ask too many kindly let me know!
I have attached just a few of my very humble collection to actually make this post interesting.
Thank you Mark for all of your fantastic videos and this forum, and also the other contributors here with vast knowledge I hope to tap.
Alec
Welcome to the forums AlecJ, as you say Marks videos are very interesting and are 1st. class. Like anything watch repairing has to be learnt and the best way of learning is by doing, try to find some junk watches to practice on. There are people at all levels here so any question's you might have are bound to get an answer on here.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
