Mrs
LouDan
We bought a Hermle mantel clock in a charity shop a couple of weeks ago, with a 340/020 movement.
It all works beautifully, except, it's not keeping time. It's running slow.
We've looked online at all possibilities of how to speed up the clock, but all info seems to point to a regulating spindle, which this model doesn't seem to have.
Do any of you clock wizards have any idea how we can sort this problem, before we take it somewhere in the New Year to try and get it fixed.
Thanks so much.
2 hours ago, clockboy said:
Welcome to the forum . You really need to post a picture or two for us to help. Enjoy the forum.
Thank you for the welcome. I will attempt to upload a pic.
We have tried adjusting the screws at the plus + and minus -, but nothing has changed over a couple of days.
As there's no regulating spindle, we are at a loss as to where to go from here.
Any help much appreciated.
Hi  welcome to the forum.  The clock you have is an eight day westminster chime which employs a floating balance assembly.  I may be that the clock requires a srvice(cleanand oil) which included the balance assembly. The balance spring floats on a helical spring centered of a wire or maybe two wires under tension . Any dirt congealed oil and the like in the tube will have an adverse effect on the timing. Regulating the balance is easy enough if you know what you are doing.  What you describe would point me to the fact that its the clock its self that needs a service and the mainsprings/train checking out for freedom, again any dirty or worn pivot holes, dry and dirty oil will again cause problems.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
There is normally a reason why a clock movement is not keeping good time. Here are the main ones. the movement is dirty, lack of oil, wear in the pivot holes, problems with the springs. I'm enclosing a link that will help you to understand the floating balance of a Hermle clock, be very careful when it comes to altering the balance.
https://theindex.nawcc.org/Articles/Murray-hermle.pdf
Thank you for your reply. We were thinking we may need to take it somewhere for a service!!! Given that neither of us have a clue as to how to possibly solve it, and the only person we know with any knowledge, only has a limited amount of knowledge, then we may have to take it for service in the New Year.
Thank you for your reply, and the link you posted too. Goodness, the adjustment looks a bit complicated and we would hate to mess with something and break it, or make things worse, so maybe taking the clock for a service is the route we will take. Once again, thank you.
19 hours ago, watchweasol said:
Hi   have attached two pages from the Hermle manual regarding the 340/020 to give you some idea of the complexity regarding regulation etc
Thank you for attaching those two pages from the manual. We think we'll give it a miss. Would hate to do something drastic and alter something that can't be fixed!
Thank you for your help.
18 hours ago, oldhippy said:
That is the best thing to do. Take it to a clock repairer, make sure it is repaired on the premises, a lot of repairers farm the repairs out or they send them away and ask for an estimate. Clock repairs can be expensive.
Thank you so much. We do know of a little local business, that does watch and clock repairs onsite, so we will reach out to them. We just wanted to check whether the problem was easily fixable ourselves, but it appears we would be better letting the experts tackle it. Once again, thank you so much for your replies and help.
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
