New user….
Hello everyone, new member here. I'm a life long mechanic, started inspecting cars at 14 for a friend who had a shop in Pa. Broke my neck at 16 so I started fixing lawnmowers and by 2000 opened my own business and ran it until 2016 when a infected kidney stone caused me to shut down.
I've always been interested in time pieces and needing a way to earn money and that I can do...Tada, watch and clock repair. Why not, I already have a good head start both in mechanical knowledge and tooling so I might as well have some fun working on interesting things and make some money as well.
I'm currently on level 2 of the watch repair course so when my practice watches get here, I will start working along with the lessons so general procedures will become familiar to me.
I'm thinking about doing a YouTube live stream on my 1st complete disassembly and rebuild.
Well in short that's how I wound up here and looking forward to getting to know a lot of good people.
jrrdw.
    • Thought I had to share this - last time I cleaned out a deep fat fryer there was less mess than this. Another pin pallet movement. Unsurprisingly dunking it in Castrol GTX didn't fix the broken mainspring which is the only issue I've found.    Any tips for the dial? Also covered in oil.
    • Hi Nev . No i didn't try this balance in the movement as it didn't run and the deformed staff broke when i removed the roller. Problem is what i think is the correct staff for this movement, the hub seat, roller and collet profiles are all too small for those parts of the assembly. The movement listed on Ranfft's site is correct my movement and the nos staffs i have match the ronda measurements. I can only assume that the wheel , roller and collet openings have all been broached to make them fit an oversized staff, both staff pivots had also been modified.
    • Yes, threw it on the demagnetizer before I cleaned it to be sure.  This picture doesn't show it well, but I can definitely see liquid where the turns meet up.
    • My newest 404 candidate, a late '60's / early '70's Waltham with a UTC 33 / Seiko 6601 17 jewel automatic movement. It needed a new crystal and I put on a strap from my Strap Graveyard. The timegrapher was a snow storm before servicing but it cleaned up nicely. I really like the funky font used for the hour markers.
    • Hi Rich, the main problem with the balance is if the roller is from this movement. Did Yoy try if the balance interacted correctly with the lever? You can use suitable (by size) balance/hairspring couple from You pile of balances, but the roller must be for this lever (original for the calibre). Not that making roller is impossible, but it is easier to have one.
