How Do You Refill Your Oil Dishes?
Maybe this is a dumb question but how do you refill your oil dishes without wasting three months worth of oil dripping down the rim of the oil jar?
I've tried straight up pour it in. This results in drips down the edge of the bottle.
I've tried polarity tricks similar to what I've used when pouring water (use a chopstick is a cup to avoid drips, etc). I this case I use an acrylic stir stick as a pour stick. Results have been better but still wasting some oil.
What else can I do?
2 hours ago, Paulj said:
I'm also very new but filling the oil cups I use only requires a few drops in the cup..... I just dip my widest oiler into the vial of oil then rest it in the hollow of the cup.  The oil will run into the cup... rinse and repeat.
Screenshot by Snip My at Dec 11, 2022 at 10:56:05 PM.png
The most sensible answer by far.
I'm pretty sure this question came up a few weeks ago? I use my No 1 tweezers, dip it into the oil container, then transfer it over to the cup - making sure the tips of the tweezers contact that base of the cup - and open them up. Voila - usually enough so I only need to do this once. Obviously you want to pre and post clean your tweezers when doing this using liberal amounts of IPA
It certainly did come up Gert, then went down a hare horifice as to the reasons why a syringe shouldn't be used. I kept well out of the discussion 😌
Clever! I'm going to try this out. Thanks!
I use tweezers as well, but just to be different I use my No.5's. another method I saw recently was to get some 1ml syringes and the finest needles available, the fill the syringe and use the needle to transfer the tiny amount needed, then keep the syringe with the rest of its contents safe until a top up is needed.  That is probably one of the less wasteful methods I have seen.
I find it depends upon the size of the  bottle but my hairspring tweezers work quite nicely. Squeeze them together insert into the bottle. It will I Or action holds a nice drop near the tip place the tip into your oil container open the tweezers and the drop will go into the oil. Just remember to keep her tweezers clean afterwards.
I've seen a bottle of older Elgin oil or it actually had in the bottle itself a small glass rod with a little ball on the end.  which seemed like a nice idea for getting oil out but you would have to have a bigger bottle and typically are Swiss bottles are a fraction of the size of the Elgin  bottle. Then later on they There are using tiny squeeze bottles
  • 1 year later...
Thanks!  I haven't started oiling yet, but I want to know before I start wasting the stuff - it is too expensive to waste a molecule!
I may try all of the above suggestions  with a cheaper oil to get my "feet wet" (and then they get slippery and I fall down! 🤣
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
