This probably looks a bit cheeky but im very new to this and found this site and thought id risk an ask.  I have seiko SRPE65K1 watch which is a few months old.  Unfortunately i dropped it and the face badly shattered and the watch stopped.  I removed the movement and it started working again there were some small shards of glass on the face.  I ordered a new crystal and left the movement out covered by a plastic cup winding it occasionally. It worked fine for around 7 days until the replacement crystal came. I fitted the crystal and the watch seemed fine I wore it for about two days then it stopped.  Im happy to try give this a go and try and sort this. If  anyone has any pointers as to what the fault might be id appreciate it.  Thanks
Hello and welcome to the forum, we usually like to have an introduction so members know whom they are talking to and their skill levels.   Can you post some pictures of the watch , front/back and the movement. Also what is the caliber number of the movement.     The symptoms you describe would lead one to believe that there are still some crumbs/shards in the movement and wearing it has moved them into a position causing the watch to stop.  So remove the movement and inspect the movement again. It may require stripping down and cleaning to remove all the debris hence the reason the caliber number would help should we be able to get a service/tech sheet for the watch in order to help you. cheers
Welcome to the form, it’s difficult to access the problem. You really need to find a qualified horologist.
Edited by clockboy
I think I can make a pretty qualified guess without such an intro.
Thanks for the responses. I believe the movement is an SR45. I did visit two shops and make an online enguiry about a professional repair. However, the best price i was offered was for a replacement crystal at over a third the value of the watch. It was also pointed out that the hands were out of alignment and other work might be required with the suggestion that a professional repair might be uneconomic. This is why as a complete novice I attempted this repair with a few cheap tools. Although I have been unsucessful I am inspired to read up on this further. Perhaps with bit more knowledge and some better tools I could consider further disassembling the watch. Im not expecting to succesfully repair the watch but I would like to have a better understanding of how the movement works. Thanks again for allowing this post and your suggestions.
Hi Adie  no problem, not sure just ask.   Have a read through the two documents it will give you a better understanding of how a watch works and the tools required for service and repair. pictures of the front/back and the movement always aid diagnosis.  The caliber number is usually under the balance wheel or on the back plate or even the rotor. a picture of the back plate with all the numbers as well.  thanks.
TZIllustratedGlossary.pdf 1612608791_ToolsfortheHobbyist (2) (1).pdf
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
