Setting Up A Loncase Clock
oldhippy
I've been looking on youtube and I have found this very good video on how to set up a Longcase Clock (grandfather clock) this is an antique not modern with a Westminster movement. I would like to say I have no connection with this person or his business. It is good it's the way I would go about the procedure and simply explained. I'm trying to add a little more to the clock forum page.
Link
I thought he would have mentioned how important it is to have the case level and that it should be screwed to the wall whenever possible to ensure sympathetic movement of the case doesn't happen. I would also have screwed the movement tight into the case.
Another very useful thing to know is how to set it in beat properly by bending the crutch.
He does mention that it could be screwed to a wall. The movement doesn't need to be screwed in side the case because of the weights they will stop the movement from moving, after all the movement is screwed to the seat board and in some cases the seat board is nailed down Yes the case needs to be level and how to bend the crutch is all to making the clock in in beat. Unless you know what you are doing bending the crutch is not advisable.
This is how a clock restorer shows how to bend the crutch.
Image from public website of Fusee Clocks in hints/tips page.
I wouldn't recommend any one  bending the crutch. Besides bending it to that extreme in that diagram its likely to break off.
Check first that the clock is level.
Then its best if possible to twist the whole movement to achieve beat. French slate clocks allow this movement with ease. I use a doctors stethoscope to aid with hearing the beat and the first move is to just tilt the clock to hear the improvement or worsening of the beat.
Then any bending of the crutch move little at a time.
    • Lots of rust on that hairspring Nev, would you even try to clean it up ?
    • How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
