Hi all, what parts should oil or grease should i put on the Barrel's of this clock sorry about the text in the photo went over it you can see it better in the other one
thanks watchweasol i have the oil and grease what parts need oil or grease do you know what the pin is for.
Edited by Willow
another question
Hi  all the pivots as usual and all other pivotable parts like the rack , lifting levers  etc,  Min wheelpost  all the strike parts, and a smear on the star wheel that lifts the hammer, and I put a smear on the Gathering pallet surface where the lever runs. If yours has a chime mechanism the same applies there also. Use the oil sparingly/    I have not found any lubrication charts for clocks yet although the Hermle Manual has instructions for their clocks which may transpose.  If I fins any at all I will post them.
Hi Here are a few guide sheets from the manual, should cover most points.  cheers
H1.pdf H2.pdf H3.pdf H4.pdf
Hi Willow I found This , you might find them useful some time.
https://r.search.yahoo.com/_ylt=AwrIS.Yk9zJjYRcACkF3Bwx.;_ylu=Y29sbwMEcG9zAzMEdnRpZAMEc2VjA3Ny/RV=2/RE=1664313252/RO=10/RU=https%3a%2f%2fwww.abbeyclock.com%2foil.html/RK=2/RS=JP4XjnRE8aAXw_5VhLYcGCzY0u0-
There is a lot of useful information on this site.
BTI-The_Practical_Lubrication_of_Clocks_and_Watches.pdf
Hi everyone, is  there a technique in measuring the line, fixing it to the barrel then the weights without getting into a tangle with the line.
Also what is that pin for that goes through the barrel is it to tie off the line? (See last photo)
Oil or grease where two parts rub, I always used grease on the ratchet. You attach the line to the pin. Use  Synthetic gut that you can buy from any good clock suppliers. Yo must make sure you get the correct length right if not the clock will not work its full time which is 8 days, and the line most not wind over the groves on the barrel. Windles clock oil is the one I recommend.
Thanks oldhippy, i have the line, grease and oil but do you wind the line on the barrel first or a to pulley and weights or dosen't  it matter which way.
To get the right length you could wind it  round the barrel if it helps you. Don't forget when you have decided you have the correct length to put the pulley wheel on, which I failed to do the first time I serviced a Vienna🤣
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
