The newest member
swiss2k
Hello everybody!
My name is Dmitrii, I am 33 years old, and I am from Zurich, Switzerland.
Recently I have started my long-time passion of watchmaking. Although I have done a lot of nerve-racking things in my life, watchmaking takes the lead at testing my ability to resist throwing everything at a wall to smithereens. The journey started when I bought my first broken Omega Seamaster Cosmic, the plan was simple, find the defect, repair and service the watch. After a month I had about 5 watches, disassembled and waiting for parts (thank God my wife does not know how many I have).
Now back to the first Omega. I really wanted to make my first build perfect, everything new, everything as the manual says and bla-bla-bla... Well guess what? Parts don’t fit!
So yes, this is how I ended up here.
Thank you!
Edited by swiss2k
Simple update
Haha. Maybe not the kind of approach to have, you desperately need to get this out of your system, if you are even thinking this way and ok maybe not acting this way then you are going to struggle with watch repair. Things have to remain calm and relaxed in your head at all times as it will effect your work without you even realising it. As with everything our decision making is based entirely on our mood and emotion at that particular moment. Favourable positive decisions and outcomes are the products of a serine mind. And before you ask no i am not religious in any way, just smart, logical and experienced in life. If you feel something rising in you head because the repair is not going well then back off for a while and grab a cuppa. I myself have a wicked temper, over the years have i learnt to control it, not easy sometimes but more than worth the effort and much better than the negative outcome.  Oh by the way welcome swiss2k, this is a great helpful friendly forum. I actually rate it the best watch repair forum in the world obviously  as i am member,  a few of the other members are ok too, sort of 🤣
Edited by Neverenoughwatches
Welcome to our little group!  I also can say I have encountered a few watches in my time that tested my patience.  And I tend to have a rather mild temper.  All I can think of to say is: be prepared.  Some watches can be difficult.
I always try to remind customers up front that some repairs take time and must not be rushed.  More mistakes happen when we hurry.  I try to take a break when I begin to feel rushed or frustrated.
I also try to prepare in other ways.  One of the most aggravating things that can happen is when a click spring, in the process of being removed for cleaning, goes "ping" and shoots away so quickly that you have no idea where it went.  So, I now place the movement in a clear plastic bag when removing them, and I have stocked up on a large variety of click springs of all kinds.  I have done the same with screws, because they can go missing too.  I have lots of screws.  I have learned that if the part is small, and cheap enough, it is good to have many in stock, because they are often the things which go missing most.
That really is all I can advise: go slow at first, do not rush.  And be as prepared as you can be for what may happen.  That, and some very good screwdrivers and very good tweezers solve a lot of problems up front.
Edited by KarlvonKoln
Perfect advice from Karl. Within a month of starting i realised as Karl has said that i needed some stock behind me to backup any losses or breakages i would eventually encounter. And yes tweezers and screwdrivers you should choose of good quality and learn to dress  and shape them accurately. It does make a huge difference to driver slippage and tweezer pingage.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
    • 👍 Whats not to follow OH ?  You're every inch a pro and a true gent, i always enjoy reading your answers even some of the clock stuff that i dont have a clue about.
    • Could you print the image either enlarged or reduced to the same size as the actual part and then glue it to the steel.
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
