To many watches to pay to service!
Yeah I know the site and the creator of it. the two video clips are good examples of the quicker method and a full tear down. the quick method will work in many cases. But not always and not for all the different movements. I strongly suggest to not bend the four tabs as was done in the first clip. Instead there are three tabs that insert into the top plate, Much saver way as to not break a tab.
I found a motor that is 3/4 hp and another that is 1.2hp. They come with speed controller. So I don’t think I would need a wiring diagram. But I sure appreciate you offering your help! Do you think 1.2 hp would be too much for a watchmaker’s lathe?
At the moment I have neither EDTA solution nor Evaporust, so I tried with a citric acid solution. This gave satisfying results for most of the parts, except for the ones that are really heavily corroded. I will see whether I can acquire one EDTA or Evaporust and try that next.
