Full cleaning process, thoughts ?
A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before: And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
Thank you OH, appreciate your input.
