complete noob
nmiyon
thank you for having me disable retired old nut trying to change crystal on wrist watch every video wants you to remove the watch face by removing the case back unfortunately the face is larger / and or being blocked by addition metal seal stuck here are the specs
Watch Information
Brand Name                           Saa'i Timepieces
Part Number                           AAW-02-TG-SL-B1
Item Shape                           Round
Dial Window Material Type     Mineral Glass
Display Type                           Analog
Case Diameter                           40.00
Band Material                           Leather
Band Color                             Black
Special Features                   Chronograph
Movement                         Japanese Quartz (Miyota Watch Movement)
below is the watch in question please offer any and all advice
Hi and welcome to the forum        With this type of watch there may be no alterative other than removing the movement and dial then pressing out the glass. The problem being then once the glass has been obtained it will need pressing back in (tool required) and also may need a new gasket for the glass to seat in.  The movement on these "fashion" is likley to be a miyota 2030/35 a common movement.  best to post pictures of the watch movement and the case. most likley has a white plastic insert which holds the movement in place and when this and the stem are removed the movement falls out.
    • Looked all over and I can't find it. Pity Ranfft movement identifier doesn't work. The closest movements I've seen, from general layout, and shape of keyless are Corterbert.
    • Well, this stickiness was only on 1 or 2 turns at first.  After using the B-Dip, I can actually manipulate the the turns in such a way that ALL of them stick on one side and I can pull them apart and you will still see a few sticking still so there is either residue from the B-dip or the initial crud that B-dip didn't remove.   What bothers me most is that I can still see liquid in-between the turns holding them together, as if the dip didn't completely evaporate.  When I get a chance, I'm going to try an alcohol or lighter fluid dip and see what happens.  I don't have a very fine brush for this, so that might have to be the next step.
    • Couple of Oris in there , early Oris were pretty small , around 28mm , the first 2 could be 45x or 49x series calibers. The Unicorn might also be an Oris, to know that these will be pin pallet watches if there is no jewel count on the dial. The other 3 will be much the same. The Oris are ok and have some value, as far as pin pallets go Oris were very good as thats all they were allowed to work with for a long time, so they made sure they got the best out of them. Its good to inside though, at the most basic level of inspection of an Ebay sale at least you can see if anything is missing inside, otherwise its just pure luck. Ask the sell if he will add some pictures of the insde for you to privately look at.
    • What I've found with Facebook groups and yes i am in a few , its good to have more than one source of information on specialised areas such as lathe restoration or just military watches etc. They dont have the same ethics that we have here, we all seem to look out for each other here, a good close knit group that encourage new members and each other daily. We have a laugh sometimes and really help each other out and support each other. All the support i received about my mum was so kind, i wouldn't have got that anywhere else. A lot of these facebook groups are full of aholes and sarcastic gate keepers. I consider our forum to be very unique, but the subject of # if it ever Dissappears # honestly i think does need addressing . We're really just after a connection site Michael not a full function chat group. Just a way to re-connect if something happens. But the other big thing is all the stored information how that can remain accessible.
    • Facebook is a big NO from me. I have nothing to do with any of these sorts of places.
