Hi I recently acquired a slava 2414 watch that has a bad click or click spring  I don’t know what a good. One looks like  does anyone have any idea what a good one looks like
Could you post a good close up photo of the click and click spring? That would help our members here tell if your parts are ok.
Wow! You have to be born under a lucky star, @BigT.
I just received this watch in my mail 3 days ago. It was procured from Ukraine and took over a month to arrive. I had almost given up on it.
I thought,  what's the chance that the movement inside is a 2414? And guess what?
Here you go.
Here you go.
Haha. BigT.  Ask the universe 🙏 politely and be good and ye shall receive. 😄
2 hours ago, BigT said:
Thank you are there any pictures of the click spring installed correctly I have no idea how it should look  when installed
Hector's photo is showing you the correct side up fit of the click. The spring fits underneath the click . One end of the click spring in the mainplate the other end in the far right notch of the click. The other two notches in the gear teeth of the ratchet wheel retaining the power. Perhaps Hector will show you it in position, he's  very nice like that.
Edited by Neverenoughwatches
Hope this helps.
24 minutes ago, HectorLooi said:
Hope this helps.
HectorLooi,
Is that the same spring from your earlier photos?  I ask because the click end in your first photo looks shorter and tapered in comparison to your last photo.
Thanks for the last photo by the way.  It will help everyone see that the straight end needs to rest against the central boss so the curved end can rap around it while winding.
Great photos
Shane
So I have this Leon Piradet watch I picked up a couple days ago, and I'm trying to get a balance for it, but I didn't know what the movement was.
And now, sitting here sipping coffee, I read this post...and here's this movement which looks just like it.  I've been checking now, and it's a 2414 all right.  So I can now confirm that Hector seems to have the click spring installed correctly (or at least the same way as mine). Suddenly all these Slava 2414.  Must've been more common than I thought.
And now I hope to locate a balance for mine - unless one of you needs parts?
1 hour ago, Shane said:
HectorLooi,
Great photos
Shane
Hi Shane,
Yes, it's the same spring. The ends of the spring are bent at right angles and in opposite directions. One goes into the hole in the bridge and the other end rests in the notch in the click.
Hi Shane,
Yes.  It's just the click ends look different.
Probably just lighting within the photos.
22432295_20220813_083736.jpg.7038ca7f3ca22edd94e1aef8ab08d6fe2.thumb.jpg.8e1a91c042397c9b0e255ff891d106b1.jpg
21906593_20220814_185348.jpg.407a465d3cf7db7a28e9f9189cc884b82.thumb.jpg.4baad16d3c864d0ecf0aa809fabd13f8.jpg
Thanks
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
