Hello all--new here--Retired airline pilot--------My question is-- How does the bezel attached to the case---I have a replica Rolex yacht master found--I have no idea who made it--but I decided to change the bezel face, so I removed the bezel---it is a rotatable kind----- There was a hole for the spring click--but none was there---that's ok as you can rotate either direction----but---now the bezel was a little hard to pry off----but now can't get it to attach to the case --sloppy loose---What held it to the case ?  It doesn't just snap on over a lip like some watches I had---real Rolex for example-----What is that slot around the inside of the bezel for ?  Driving me crazy to figure it out---any help appreciated--Thanks   SAMe
These are are snap on indeed. If your fake doesn't really, that just demonstrate its poor quality.
I was told there is a spring wire that goes into the groove in the Bezel ----to snap it on----it's not the click wire
I guess that might be as the bezel is just loose, but the case has a groove---Esslinger sent a flat spring washer---but that's not it   It was tight on there-- a little hard to rotate until I popped it off and maybe something fell out--looked but didn't see anything--- Anyway, thanks for your reply
Hi  A picture of the underside of the bezel and the front of the watch would be helpful in determining the problem.    On some bezels there is a wavy flat spring that fits under the bezel and then the bezel snaps on , the spring prividing the tension for the bezel.  There are others in which there is a small hole in the case with a spring and a bearing (a Biro ball is some time used as a replacement) which detents on the underside of the bezel.                thanks
Any clicking arrangement does not influence how the bezel is held to the case, which invariably is snap on. Check that the bottom of the bezel is all the way down to the case, if it was very tight to remove will need a good case press to be put back.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
