Hi
Finally I have found my old watch that I last used over 20 years ago. It needs a new battery but I can not see what it says on the battery that is in the watch.
The watch is a citizen 3801-450981 TA
8 minutes ago, LBe said:
Hi
Hi, i think it may be an sr920sw / 371 battery
Someone will certainly tell you what is needed but I think that teaching on how to do by oneself is more valuable that serving the ready solution.
1. get yourself an eyepiece or at least a loupe. Very very important when dealing with watches
2. measure the old battery, that will give you right away the size because diameter makes the 1st digit, and height the 2nd and 3rd. And I am attaching a document to better make sense of that.
7009_Battery Cross Reference Guide.pdf
3. if no battery, measure the slot and proceed as as above.
4. if no watch, there are many websites carrying this information. Normally, in the first hits of a Google search result.
Edited by jdm
I have not been able to find anything about  3801-450981TA on google but i can see better now using brighter light.
I's a 371 🙂
I'm just so excited.
Hope the watch will be up and running again with  new battery
As long as the old one had not leaked its contents and done circuit damage I am sure it will work with a new battery, unless the mechanism has got a little gummed up sitting there doing nothing for nearly 20 years. One of those cheap Quartz tester might be needed to shock it back to life, they are a very handy gadget for the Quartz owner, they can listen to the pulse generated and spin the hands which can clear a stuck movement.
unfortunately even quartz watches need servicing from time to time if the lubrication's go bad that can be an issue but usual a quartz watches seem to run considerably longer and sometimes people consider that they never need servicing because they run so long. although you do have to be careful of quartz watches are very intolerant two things falling in the and other was sloppy battery changes can result in a heck of a lot of destruction coils are favorite thing to destroy. Or just dropping things in because people don't brush the backs off before they take them off.
then I found a tech sheet for your movement
2634_Citizen 3800,3801,3802,3810,3811.pdf
3 hours ago, LittleWatchShop said:
SHOCKED!!! SHOCKED I TELL YOU!! @JohnR725finds a tech sheet on some obscure Citizen movement!
Personally i think he wears a top hat and cape and carries a black stick that he waves around while casting an appearing spell. If that isn't blowing smoke up someones arse then i dont know what is lol
And this was actually a thing practised on drowned victims a few hundred years ago.  😳 . Really i ask you and people say that I'm wierd.
Gummed up was the wrong word (No surprise there) and yes they do need servicing, if the movement fitted can be serviced unlike for example  the one fitted to the new Swatch-Omega Moon watch 😞 but I have found they can need a little help starting if sat idle for many years with a flat battery.
These 4 in 1 quartz testers can be quite useful to determine if the quartz and cmos is ok and to even test the quartz crystal by itself to eliminate component breakdown.  But i did try the freeing mechanism on a couple of watches that where running fine as i was curious. One of them ceased to work afterwards so I'm sure its not a good idea to have it whizzing all the hands backwards and forwards. If the movement is gummed up with old oil , there is going to be some stress placed on it by imposing undue forces. And if its not cleaned and serviced instead then the dried up oil is still there and will start to lock up the train again anyway.  Really best to service them, they're not difficult. The train is smaller and more delicate but there is much less to work on. The only troublesome lithle bugger is the rotor, but we've duscussed how to deal with him last week. There is a few pressed together movements that are not servicable but to buy complete are pennies. I dont like to dismiss any watch but these are not even worth a mention tbh.
I'm dying to know how many of the wierdos amongst our group are googling this. Just so i know what competition i have. Lol.  And if any of the more wierdo are going to try it then i suggest a oneway valve in the tube and breath in through your nose, as the after taste is most definitely an aquired taste 😂
Edited by Neverenoughwatches
My point went right over your head.
I consider @JohnR725  to be the Google of watch knowledge...a high compliment.
10 hours ago, watchweasol said:
Not Magic Its just knowing where to look,  And John has the knowlwdge, I also have a computer full of info . Cant have too much .    attached the 3800 base caliber tech info for you Citizen guys
yes the secret of where to look and what to look for.  on my bookmark toolbar for the most part there is no individual bookmarks there are just folders of bookmarks. Watch repair related stuff takes up to folders otherwise the list goes down the page too far and it did allow me to categorize a variety of things.
Then of course it's really nice that computers have much bigger hard drives than they used to have sizable quantity of  PDFs accumulated over a very long time and continuously being updated with more and more of them.
John is our resident watch wizard
I just happened to be the first  person here there are others on the group that will post tech sheets also. so I don't work alone here this is a team effort there iare other people on the technical supplying team. although that's an unofficial team we don't officially exist.
And you are all very much appreciated John thank you . Without all the help that we are receive us beginners would find it so much more difficult. So you may not exist officially, but you are most definitely recognised my friend. 👍
  • 2 years later...
Looks like the battery you need is a 394 (SR936SW). Just double-check the size and voltage before buying to make sure it matches your watch's requirements.
and if the AG10 battery is a snug fit in the compartment and meets the voltage specs, you should be good to go. I’ve swapped in AG10 batteries before without issues, as long as the dimensions match and there’s no risk of loose contact.
You shouldn't be using any Alkaline Batteries on watches due to leakage potential.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
