Single Speed Or Variable Speed Polishing Machine
DJT2
Hi guys, I'm in the market to buy my first polishing machine. I'm wondering if there are any recommendations? I'd say I'd be comfortable with spending upto £275. I'm just getting a little confused on what spec would be the most beneficial for me. Ie.. Do I require 8", 1/2hp, 550watt, variable speed etc. Any help or advice would be welcome.
No need to spend a lot of money buy the likes of this http://www.screwfix.com/p/scheppach-bg150-bench-grinder-150mm-240v/28349?kpid=28349&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&kpid=28349&cm_mmc=Google-_-Shopping%20-%20Power%20Tools-_-Shopping%20-%20Power%20Tools&gclid=CPX70uKA88UCFSkGwwod2XUA9gand fit with a set of these http://www.metalpolishingsupplies.co.uk/bench-grinder-polishing-spindle-adapter-set-1-2-12-5mm/?gclid=CNLNup2B88UCFQKK2wodm30AfQ
I have been using this setup for polishing metal for many years now, but I still prefer to refinish watches by hand to ensure there is no damage to edges and sharp profiles. Only very occasionally will I use a small buff on my Dremel.
Unless you are going to be polishing plastic, you don't really need a variable speed machine.
PS. I'm not saying to buy the above, they are only to illustrate the type of polishing system I use.
I must admit I've seen you mention that you generally hand polish watches & as I've only ever polished the sideboard before, I've looked for videos on you tube for hand polishing watches & can't find any. The only stuff I can find is with machine polishing. Hence getting the machine.
I just have finished modifying dual table grinder from Lidl to adopt it as a polishing machine. It seems to be solid and not very expensive. Im not doing much polishing so for my needs its enough. I added speed control module to it (DIY kit for speed control from one of the shops with electronic stuff, I had to solder but that was fun). Module fit inside case of grinder and only change I had to do was drilling hole for knob for changing speed). I used connectors to put it into circuit so it can be back to original state at any moment, just unplug module and pug it back as it was. It runs quite nice, 200W its enough power, motor seems to run smooth and don't need any maintenance. I can use polishing wheel sized up to fi 15-20cm, up 30mm wide. only problem was getting wheels with proper hole size as it accepts 13mm, so I have to use adapter from 20mm/13mm. All together cost was about 40$ for the device. I can post pictures when I get home.
btw. speed control may be needed if felt wheel is used - too much speed and it can give you burn marks on metal.
Edited by Rafal
Looking forward to seeing the pics. I was toying with trying the same thing, however I wasn't sure what size motor/watt & rpm I'd be looking for when purchasing.
Here are the pictures. I believe Cousins sell cone shafts which could be used to attach polishing wheels. This is first draft and I plan to make improvements :). From behind, just by power cable, you could see knob for speed control. That was the only sensible place for it.
post-1017-0-12164600-1433352419_thumb.jp
post-1017-0-02525700-1433352425_thumb.jp
Edited by Rafal
I'm with Geo, and pretty much have the same reference.
The following related videos may come in handy for you too on how to prep your wheels.
Put the kettle on, they are 70+ minutes (combined).
Edited by SSTEEL
https://www.youtube.com/watch?v=2jnJe2jANms
https://www.youtube.com/watch?v=YMuWrI-sCj8
I've watched them & they are really informative. I even looked at buying the exact same Ray Foster bench polisher that was in the video £350 but just can't justify it at the moment.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
    • Sorry to jump in here, but I didn't want to start a new thread when there's already one regarding the second hand watch market. Can anyone tell me what I should be looking at when buying watches from eBay? I see loads on there for quite cheap, but after reading this thread I'm guessing they're all garbage and not worth the time? I recently bought an old Elco watch for 99p, just to practice on. I'm also really fond of the look of Services watches and Smiths Empire watches. I keep seeing them listed for around 5 or 6 pounds. Are they not worth the time buying? I'm not looking to sell watches to make a profit. I just want to buy watches I like the look of and wear them, but I also don't want to buy things that are going to be impossible to find parts for, or that have already been abused by someone else and broken beyond repair. Any tips?
    • I tried the Moebius 9415 from any sensible amount, down to microscopic a drop (or "super minimalistic"); the size of droplet which makes you really wonder why one would/should apply anything at all? But to no avail, consistently a lower amplitude compared to my Dr.Tillwich 1-3. Of course, as John mentioned above, the Dr.Tillwich 1-3, just like the Moebius 9010, likes to go somewhere else. Since short however, I'm the (proud?) owner of a bottle of Moebius Fixodrop. Can't say that I'm a proud owner of the 9415. So far, I haven't seen or discovered the "magic" of the 9415. Meanwhile, Moebius 🤣 has my money though.........
    • I used to be quite active on The Lotus Forum when I owned my Esprit. I was there for so long, Bibs asked me to be a moderator. I'm not sure how long I did that for, but I think I turned into the second longest serving moderator. When I 'handed back my keys', Bibs made me a Full Forum Member. Normally this is a paid membership. My reward I suppose for helping out for many years. Bibs (forum owner) is quite active on there and if I am not wrong, don't quote me in other words, I think he once said that the money from memberships didn't cover the running cost. He adds money himself to keep it going. Does Mark have any sort of subscription scheme on here? I'll admit that I never paid to be a member on TLF. I should have. I never did. I agree that it would be a good idea that there is some sort of contingency plan for this forum. I intend on becoming more active on here. Life has just been getting in the way recently. I enrolled on Mark's watch course and was keenly doing that, but even that has had to take a back seat for a while. I am looking forward to getting back into that and also starting to do work on the clocks that I have been amassing. To do that successfully, I see myself needing to lean on the other members here. If for whatever reason this forum was to close, I think a great many of us would struggle.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
