What should I do for my first attempt at changing jewels
Which was the standard for years https://de.m.wikipedia.org/wiki/Epilamisierung
By watchweasol · Posted
Hi first we need pictures of the movement and watch to determine the calibre ans as Neven said whether it’s worth repairing or not. Depending on the maker and its construction. -
It kind of makes sense to me , to rub out the Epilame so beneath the oil is a more adhering surface. I started an experiment but its not exactly accurate as I'm using stearic acid. Surely a simple test of dragging oil around on an Epilame coating with an oiler will answer the question. Will it pull away from its position or will it resist being mobile. The oiler replaces the mechanical drag of the escape teeth. Exactly, why set themselves up for complaint. Here's our product you figure out the best way to use it. I feel a patent coming on, I'll be Rich yet. -
I think that tells us precisely nothing about how their product works, and I suspect that is intentional.
