Not that deep. If you want the easy way I would fill it with silver solder, soft solder will wear out in no time. Make sure you burnish it and the inside of the hole. The best way would be to make the whole steel piece, but you need a lathe and mill but you could do it with just a lathe. Depends on your skills.
ill go with the easy way to start with, my mentor suggested to file it down, i think just to test my skills further.
Although the amount of pivots I've filed and burnished with him I'm quite adept at it now. ill let you know how i get on. many thanks
I don't think it would be too weak if you reduced it down below that groove. I would definitely turn it down in a lathe, then burnish, to be sure it's nice and round and straight.
The photo looks to me like that pivot may have been gripped in a vice before. I've seen that many times. Sometimes they end up ovalised as a result (you can feel it as you rotate the arbor on the lathe).
Sorted this pivot, had to file it down by quite some way but there’s still enough meat left for the size of the pivot.
Obviously I had to bush the hole, and before anyone says it looks abit rough this a before the finished burnished pivot shot3AA09491-DEF8-45B6-B6B1-AF1DB485D572.thumb.jpeg.6046d50ba7996ebf18addd5f52e6272d.jpeg
Just looked at the original photo and that is a lot of steel removed. It looks sturdy enough and I would say it will be fine. The fusee cone takes a hell of a lot of pressure.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
