New hobbyist with a question about Agassiz movement
Hi all.  I'm a newbie to watch repair but really enjoy this forum.  After retiring 3 times, i decided to take up watch repair.  I'm in the process of making all the mistakes I'm sure everyone else has made, but I enjoy the challenge.  I recently acquired an AGASSIZ movement SER 122815.  Engraved with Tiffany & company on the movement and a very handsome dial with Tiffany & Co. on the face.  I'm trying to figure out how to service the main spring barrel, but have never seen one like this.  Any thoughts on how to proceed?  And OBTW, I need a winding stem as well.   Any thoughts would her appreciated
Hi  And welcome to the forum,  It is a handsome watch  indeed.  The barrel has attached a "stackfred" in the old parlance, what this does is limits the wind to the center part of the spring therfore maintaining the same tension on the train. There is no full pressure on a full wind and conversley as the normal spring winds down the pressure diminmishes. . so by that the use of the "Maltese cross work" ( another name for it) the watch uses the even pressure from the center of the spring.  From memory I believe it takes six winds of the Key/crown
It also prevents the arbor from slipping off the mainspring.
This is a rather high grade movement, I wouldn't recommend it for learning on. Parts will be unavailable, I would imagine the stem would need to be made.
But if you want to proceed, the ratchet wheel should pull off the barrel arbor, it's held by the square, and kept from coming off by the barrel bridge. it could be a bit of a fight getting it off though, as it's been in place probably for decades. You would then grip the square in a small watchmaker's vice, and turn the barrel so that there is no pressure on the stop finger, remove the finger, then let the barrel unwind, noting how much pre-tension was applied. Most mainsprings will develop 6 turns of wind, and this stopwork allows 4 turns, so it would be typical to have one turn of pre-wind and then the stopwork will stop before the last turn, leaving one turn that doesn't get used.
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
