Tommy women's watch battery
Hi folks...old man  here, with a son who thinks he can fix anything!  I got into his battery change of his Mom's Tommy Hilfiger watch ( Model: 1781715) too late I guess....hope you can help...I have tried to assist, but even with all the you tube help...no luck on removing the back of the watch to replace the battery. He has virtually scratched the back imprint off with his efforts.....tried small screw driver to lift off, knife blade to pry off and anything else that makes sense for a pop-off back.
Any assistance would be appreciated!   "~ Michael
10 minutes ago, imoonin said:
for a pop-off back
Are you sure it's a pop-off back? It could be a screw-in. Screw in backs don't all advertise themselves with a half dozen indentations around the circumference (and I don't know what Tommy Hilfiger watches likely have).
I suspect you have a department store nearby where they change batteries?
You will also likely get better help by asking your question here. This INTRODUCE YOURSELF area is intended to actually introduce yourself - the assumption being that you're interested in watch repair and are planning to stick around.
It is possible that the back will simply unscrew using one of these. Some years ago I tried to replace a battery in a pop open back and broke the crystal when trying to pop it back on. I ended up replacing the watch - it was cheaper (and less embarrassing).
Good luck!
But then again cheap fashion watches are often snap backed for cheapness
If you look around the edge of the back with a loupe you should find where to insert the edge of a case knife. Unfortunately some don't even have that option as it's cheaper to not have the cutout for the knife and will need a more elaborate back opener, like one of these https://www.ebay.co.uk/itm/225002213763?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=3BWNpbSeRqW&sssrc=2349624&ssuid=cJqjENlHSBe&var=&widget_ver=artemis&media=COI have not yet seen a screw back wrist watch that was not obvious in some way that it was a screw back, pocket watches yes but not a wrist watch, especially a modern watch.
could you post some pictures showing the back
Yep thjat looks like the correct case opening position, provided its the same or similar watch most but not all snap back watches I have seen seem to have something similar.
Edited by Paul80
If getting the caseback off is that difficult, getting it back on will be equally challenging.
Usually for small, ladies watches, you'd need special tools for opening and closing the caseback. If you're only going to do this once in a couple of years, it'd be better to bring it to a jeweller or watchmaker.
21 hours ago, Kalanag said:
Should be this watch. The red arrow shows the point where the case back can be pried off most likely.
Good answer....still no go! Going to "cave-in"  and have some else do it.....this watch has been good, but a pain now......thanks for your help...MM
No you haven't tried anything, as there are special tools that become especially useful in the hands on of unexperienced people (take no offense as this category also includes most high street jewellers improvising battery changes). You can see them searching this website,  that being said what they do can be done with a sharp blade, a good holder, skills and dexterity,
Hi Attached below are just two of the special tools for removing case backs, once having done that they need to be re fitted  again I have attached two examples.  More often than not the back can be removed  and re fitted esily enough but when problems occur you need the correct equipment.
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
