Hairspring Made of Blue Carbon Steel
I'm working on a vintage Omega 620 for my wife which had a bad hairspring along with needing a new mainspring and a lower balance shock (incabloc) setting. I purchased a donor movement that had a good balance, and the setting I needed...the mainspring I simply purchased from CasKer.
The steel of the hairspring is the blue carbon steel and not the white steel that I've seen in every watch I took apart in my short time tinkering with watches. When did Omega stop using the blue carbon steel springs?   I don't want to put in a hairspring if its not the proper type steel.
The movement it came out of is from 1968.
Thanks
Hairspring's grade is what matters, I am not sure if the color indicates the grade.
Traditionally hairsprings in Omega are high grade I think grade or No 1 , there are No2 up to five I believe.
It's not like you really have a choice here? Hairsprings are usually not replaceable usually come with the balance wheel. Then as others have pointed out just because it's blue in color doesn't mean that it's steel.
That's what I did...I took the entire balance, cock and all from the donor movement along with the lower shock setting.  But when I saw the color of the steel, I'm no longer sure if the hairspring and balance wheel from the donor is the proper match.
If the monometallic metal that Joe mentioned did come in white and blue, I'm comfortable with that and will proceed with the rebuild to get it on a time-grapher.
@PostwarO27   If you are anything as terrible with dynamic poising as I am, then we can't tell a Chronograde oscilator apart from a regular one anyway. I go ahead and fix the watch with what you got, it'll run accurate. I mean you don't plan to send the piece in for COSC approval do you?
Oh just noticed you scavanged the whole balance complete from the donor, its just adjusting for various positions then.
    • I for one would have to pass, I'm not joining Facebook.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This might be helpful for you.  704789946_TZIllustratedGlossary(2).pdf
    • I take it that you're comment re the Unicorn is 'tongue-in-cheek'? Would any of the watches that are on the link I posted be likely to be radium watches? What period was that prevalent in and when did the practice stop?
    • As much as I hate Facebook, can a forum-like place be set up on there? Free and the ownership can be taken over by the next person whenever.
    • I existed before the term mechatronics engineer existed. I had to combine electricity, electronics, pneumatics, hydraulics and computing just to keep my own equipment working. I have never sub contracted any of my own repairs to the suppliers because I know I could do a better job. For a long time, dental suppliers in my country would bring their dead equipment to me that their own engineers cannot handle. I have accidentally embarrassed a couple of hospital heads of engineering by demonstrating their inadequacy.  I think mechatronics is the most under-appreciated, under valued of all the engineering sciences. I had a part-time dental assistant about 25 years ago, who was studying mechatronics in the polytechnic. She was absolutely clueless about the job prospects for a mechatronics engineer. I asked her about her aspirations and she replied that she really wanted to work in the games industry.  In our dental profession, equipment have evolved from simple mechanical to electro-mechanical to logic-driven electro-mechanical and currently to computer driven machines.  The medical equipment suppliers who employ mechanical engineers and/or mechanical engineers cannot cope with the repairs of the newer equipment. And many times end up changing whole modules and whole machines just because they cannot repair them. But I think HR is afraid to employ a mechatronics engineer just because they don't know what a mechatronics engineer does. Mechatronics is much more fun. It combines almost all of the engineering sciences and produces an all-rounded engineer. But until HR changes their mindset, not all door will be open.
