Inspired by the Mastercraft winder I tried to use its principle for a „quick and dirty“ mainspring winder.
The spring I used for testing has an arbor diameter of 2,2mm (left wound) and the barrel has an ID of 8mm. The mainspring has a hight of 1,2mm. So I found a washer with the right thickness of 1,2mm, drilled it to 7,5mm ID and cut a slot in with my dremel. Then the washer was fixed to a board with three tiny drops of super glue. I used the original lid and arbor and my pin vice to complete the tool. The rest is selfexplaining looking at the pics. Any thoughts?
Edited by Kalanag
  • Like 11
I‘d like to add that instead of the pin vice the original ratchet wheel can possibly be used to turn the arbor and wind the spring. It‘s fiddly but…
Edited by Kalanag
Brilliant. If the arbor is to be re-used you want to make sure no damage comes to it during the process.
Edited by Nibbler
I've never been able to get enough of a grip on the arbor to turn it.  Even if just to turn it a half turn to get it to engage the notch in the spring properly.  I think i'd be worried about clamping a pin vice on the bearing surface that tight.
I did manage to make an arbor out of same brass rod.  All the arbors from the K&D adjustable winders I have were too large for a Seiko 2539A mainspring.  So some 1/16" brass rod with a notch made in it with a dremel worked great.  Probably won't last long, but it actually worked better than the real arbors.  Easier to disengage by turning backward.
Hi  The main thing is did it work and no damage if yess then smart thinking. As xyzzy said might be better to fabricate a false arbour to avoid damage to the original surface.  with a little inginuity you could improvise and make a set as an when required a clever alternative to the expensive  winders.  I like the idea.
I clamped the arbor on the pinion square not touching the bearing surface! So even transfering the torque required to draw the end of the automatic spring in is no problem (with a little help of tweezers).
Edited by Kalanag
I've tried that, but the square part of the arbor is was never long enough to get a grip on with the pin vice.  Maybe I just need better pin vices.
Necessity is the mother of invention.  Well done.
I thought it was a lack of money was the mother of invention, well it has been for me over the years with some of the gagets I have made 😉
Brilliant way to emulate the Mastercraft winder! Nice idea taking advantage of the pin vise versatility.
However, what was your experience when pushing out the tail of the mainspring? It is quite a stubborn part to push out. It gets stuck between the plunger, causing the inner spring to coil over and leave the tail end sticking out of the mainspring barrel. Modern winders have very tight fitting plunging mechanisms to avoid this from happening.
I built something similar to this in the past and faced this issue.
5 hours ago, Zero said:
…However, what was your experience when pushing out the tail of the mainspring? It is quite a stubborn part to push out…
You are right! I first pushed the outer part of the spring with a screwdriver out a bit and into the barrel enough to being caught by the barrel wall. No problem with this method.
I‘m still experimenting with my „washer winder“ and the left wound mainspring of a tiny Citizen 6900 with an 8mm barrel and 2,3mm arbor.
I have to confess that grabbing the arbor on the squared portion of the pivot with a pin vice might not always work. Having a single Chinese winder for ETA 2824 with a right wind 2,5mm arbor I tried to use this arbor (the barrel is to large).
The advantage of the washer method is that you can drill the appropriate barrel diameter easily and that it doesn‘t matter whether your spring is left or right wound. You just have to flip the washer the right direction before pushing the wound spring into the barrel.
Here are some pictures showing that it worked fine. Interestingly the washer was not required to be glued in place. I could prevent the free floating washer from spinning with some axial pressure or one finger easily.
Edited by Kalanag
Here are some pictures showing that it worked fine. Interestingly the washer was not required to be glued in place. I could prevent the free floating washer from spinning with one finger easily.
Desperation is the mother of innovation. I Like It! Cool idea.
Even if I invested in a priceworthy 10 sizes Chinese winder set I wouldn‘t be able to use one of these winders for this specific Citizen mainspring/barrel 🙃
New main springs for this caliber are not available anymore.
Edited by Kalanag
Great idea, well done. I might give that a go for "odd" sized barrels.
I only have a small winder set, so I've made a couple of extra parts :
I use the 10.8mm size most but often the arbor is too big for the spring. So using a bit of brass tube in the winder hole allows the next smaller arbor to be used.
To allow left hand springs to be wound, I made a couple of new winders. It's not hard, I only have a Dremel type drill and hand file. It's all brass apart from the pin - where I drilled a hole, knocked a bit of steel in, and filed to shape.
Is your pin vice teeth too sharp for smaller barrel arbors, causing damage? Maybe it is possible to purchase a specific "blunt" pin vice that will work for this instead of the Chinese winder handle?
Edited by Zero
Or, use a scrap arbor. You could put a threaded rod in the hole, to give the pin vice something to clamp.
…or screw the ratchet wheel to the arbor and super glue a little nut on the ratchet wheel. I’ve tested this successfully. Lots of options!😉
54 minutes ago, Zero said:
Is your pin vice teeth too sharp for smaller barrel arbors, causing damage? …
Eventually my pin vice slips off the square while winding . Not good either!
Edited by Kalanag
  • 4 months later...
I must say that I am very impressed with your ingenuity. I am one of the lucky few who owns a Master Craft Mainspring Winder, in mint condition as well. Well, what I wanted to say is that the Master Craft transfer plates are significantly thinner than the springs. I think it helps to ease the weaving of the spring into the transfer plate.
  • 1 year later...
I see that the Master Craft only comes with 2 arbors. Can it handle any size of the inner coil? Just curious how with only 2 arbors it could wind mainsprings that take an arbor anywhere from 1.5mm to 5mm?
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
    • What browser are you using Rich? Fine for me using Chrome
