Benrus Citation Electronic
I just received this non-working Benrus Citation this afternoon.
I had a hard time getting the caseback off but managed it with the use of my bezel/caseback removal tool.
Initial testing shows that the pcb is shorted. The balance seems to be ok and swings freely.
I removed the pcb and tested the coils. It appears to have 2 coils and resistance test shows that the coils are ok.
The movement is an ESA 9158.
Does anyone happen to have a copy of the ESA 9158 service manual. A circuit diagram would be most useful.
TIA
Here is a close up of the circuit.
There is just 1 component that I can't identify. What is that silvery blob connected across the resistor? Logically, it should be a capacitor but I've never seen anything like that.
Probably I need the assistance of @LittleWatchShop. What's that mystery component?
My initial guess is that it is a diode used to snub reverse EMF when the transistor turns off causing the collector voltage to swing beyond the positive voltage of the battery.  Standard practice when driving a coil.
There appears to be some non-factory soldering going on there.
I did an image search on google and I see similar sub standard soldering work. I really wonder what's going on.
I also see some models with a blue metal can device.
I guess I need to dissect it out of the epoxy and test it on the bench.
You have access to the terminals of the device, so you can test to see if it is a diode.
Can you point to where the coils are connected?  I cannot see from the images.
The other image you posted makes me think it is a capacitor...so I am leaning that way.
I can't figure out the layout of the circuit yet, as the ends of the coils are embedded in epoxy and soldered to terminalswhich have tracks embedded in the green plastic molding. I'll work on it tomorrow and hopefully produce a schematic.
Typically in electric watch repair there are no schematics. That's because typically in watch repair you not repairing at the component level. It's a module or circuit board it's not component repair. This only becomes an issue if you're trying to restore vintage and the manufacture it never anticipated that you would be doing that so as a consequence there are typically no schematics.
Strangely enough there was a discussion of this movement just a little while back
https://www.watchrepairtalk.com/topic/22373-esa-9158-nos-case-for-balance-complete/
then to me your mystery component looks like a tantalum capacitor. Maybe it's a regular electrolytic capacitor but that's not what it looks like to me.
That was my guess too. But I've never seen a "naked" tantalum capacitor. There is no epoxy coating with any numbers or colour code.
Does it make sense?
Yes, it makes sense.  The capacitor is a very high value...perhaps 1uF.  It is a short circuit at the oscillating frequency.  The resistor is there to bias the transistor.  Maybe the coil resistance is 5K which without the 2.5M resistor (RGG is 2500000), that would bias the base current at 200u which is probably too high.
Thanks @LittleWatchShop
I think the tantalum capacitor is shorted. I'll probably need to rebuild the circuit as all the leads are actually factory spot welded. I think you are correct, someone tried to repair by soldering it at a later date.
You should be able to find one small enough size.  Alternative would to use a 1206 SMD capacitor...just a little trickier to assemble.
Going the SMD route, I would do this surgury and attachment.  You just cannot let the heat stay long, otherwise the other joints will melt.
2022-05-10 17_00_26-Benrus Citation Electronic - Watch Repairs Help & Advice - Watch Repair Talk — M.png
    • I have two Seitz sets, one ancient (with the 3mm anvils) and one just old (with 4mm anvils) plus a collection of spare pushers of assorted vintage. Not one of them is marked with it's size. Something which I have found very irritating when I have been using the tool and not returning pushers to their correct place in the tray every time as it means that I have to get the calipers out and measure them. These were bought as sets and collectively I have over 100 pushers so it would seem highly unlikely (if not inconceivable) that they are all cheap knock offs, especially as they are old enough to pre-date the prevalence of the Chinese knock off industry (at least as applied to watch making tools). I therefore believe them to be original Seitz parts. And there is no numbering. The shape of the bottom of the pump pushers is the same as your photo. The only thing that may not be the same is that the slotted insert (looks like a screw but is in fact a bayonet) should be brass. Yours looks the same colour as the steel but that could just be the lighting.
    • The original database is available on iOS devices here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
    • I no longer have my set so I can't help anymore sorry. Many on here have the set as its a must have tool for watch making/ repair.
    • It needs to be stirred before use and that makes it feel a lot thinner than when in the bottle. Does it feel as thin as 9010 after stirring it? I guess not! Yes, it's strange! I don't know, but if it is on impact it would make sense.
    • Thanks, OH! I agree with you. I'm currently looking at them under magnification, and they are consistent in shape and form for each section (flat pushers, pump pushers, concave, reamers, etc.). Though, a few are in bad condition and need to be replaced.  Before I cancel the return I have already initiated on eBay, can any of our members check to see if there are inconsistencies in markings on their sets? Also, I have included a snapshot of the bottom of one of the pump pushers, which are very unique in shape.  Can someone tell me if the bottoms of their pump pushers match this photo?  I'm hoping that Seitz had some inconsistencies in manufacturing over the years regarding markings.  Crossing my fingers. I appreciate you guys. Frank
