Hi there,
I'm not quite sure how I ended up watching one of Mark's videos on YouTube but it immediately had me hooked 🙂
The forum looks great, I'm looking forward to diving in!
Hi @shaigh
Do you have any watch movements that you are planning to work on?
Where are you located in the world - there are members here from all around the globe.
Welcome to the forum.
I'm in the UK. No, nothing to work with just yet, when I have some time I'll take a look on eBay. I was thinking of getting a working Seiko 5, they seem to be plentiful - is that a good place to start?
I know there are folks here that know Seiko well. I can't say if it's a good place to start. Some say to start with an old pocket watch because they're bigger. That's where I started and I wouldn't say that I'm happy yet with where I am now. Starting with a working watch might be a good idea. I think those of us who watched a lot of YT videos and saw a dead watch brought back to life in 45 minutes might have unrealistic expectations... 🙂
On 5/9/2022 at 1:58 PM, shaigh said:
Hi there,
Welcome matey. Looking forward to seeing you take the plunge. 👍
Welcome.
just make sure you start with watches you don't mind writing off, as there are plenty of easy silly mistakes to be made at the start.
good luck.
    • Hello, I recently bought a Brenrey watch cleaning machine. It is in really good condition but the motor speed control is not great. The motor start at relatively high rmp, it can go faster but not slower or stoped by turning the knob. I think it is the rheostat but outside YEC F-50 there are no other markings on it. It measures 1550 ohms max resistance.  Does anyone know what should be the specs of a rheostat or potentiometer to replace it? Thank you in advance.
    • Interesting, thanks for the detailed post. I saw one of those Swiss Nano machines a while back in another youtube video from  the Weiss Watch Company.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
