9ct gold emporor watch
5 hours ago, Jamesjamesjoc said:
What do you mean not genuine and what do you think the value of this watch is, regards!
He means that is not "fully swiss made". That aside, your watch market value is not much. perhaps 10 GBP if you can find someone wanting this style. The crystal could be replaced for say 5 GBP by an honest repairer, again, if you can find one.
As said already Emperor is not a Swiss brand anymore. That‘s why „swiss mov‘t“ is written on the dial. So the value of the watch is more or less the material value of the 8ct (37,5%) gold case with gold (?) bracelet. I have no idea which percentage of the watch’s 35g is the weight of case and bracelet. 8ct Gold is about $20/g.
Are there any gold stamps on the case and/or bracelet?
Edited by Kalanag
On 5/9/2022 at 1:17 PM, Jamesjamesjoc said:
Hi just bought a whw 9ct gold emporor watch would like to know how much to have the scratch on the glass repaired and what people think the value would be on this watch it 35 grams
Watch value little more than the actual weight of its gold content. It has a swiss quartz movement hmm probably not great 80s 90s Ronda ? If its sentimental keep it. If you need the cash then best gold scrap value you can find, a pawn proker ? Gold has been going up steadily past few years. If anyone on here Definitley knows whats happening with the gold market then please ring me i have spare cash under my floor boards that nobody knows about.
Oops 😄
Oops 😄
How much would you pay, regards!
44 minutes ago, Jamesjamesjoc said:
Sorry wanted to know what you would pay for this watch so I know what value I should put on it, regards!
Personally i wouldnt pay for it as its not the sort of thing i like.  And i would have to guess that inside isnt up to much. If you are selling then maybe only scrap gold value, its weight would have to calculated. So probably striped down to its bones. I would first see what is inside. Stick it on epay with a reserve price of its gold value plus epay fees, bere in mind if it doesn't  sell you are slapped with a non sale fee for the privilege of the reserve price hold .Good luck.
Edited by Neverenoughwatches
 Your question has already been answered.
Here
For a more precise appraisal I recommend jewelers forum.
Regds
Here
Regds
Hmm you're right just a bit more precise nucejoe. I think maybe a little undervalued at 10 notes, unless the gold market has completely crashed and we are now finding nuggets on the beach. Wheres my floppy sun hat and metal detector ?
  • Sad 1
 WRT forum is not a jewelery store, we are here to learn watch repair, recently however a good 98% posts have  had no educarional value whatsoever.  We have seen @jdmback quicker than you can find your floppy hat.
We love this forum and like to see it maintain its scholastic prestige.
Rgds
Point taken 👍. Although some people  like to know what things are worth. And the guy did start his introduction thread regarding the value of his watch. Not particularly interupting anything important.  Just saying. 🙂
I dont understand what this means though.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
