Help with my BENRUS (no moment number on case, but it looks like a Citation Model)
The diameter of the dial side is 40mm, and the other side 36,5mm. Here is another picture
The chronometer on the dial might just be a brand name, looking back yes i was mislead by the mention of Remontoir inside the case. Still not sure why it says Ancre Remontoir which translates to anchor winder, i imagine that means lever winder which still suggests to me 2 winding springs. I'm sure i have that same watch with chronometer on the dial ,I've never ventured inside it. My missus looks after 90% of my watches , so i will get hold of that one and have a look inside. Haha no not a remontoire, looks very basic. Good to see the keyless works, can you measure the plate size to cut down on the search for them. Can you lay out that brass bridge cover as well please next to the other 3 pieces. -
That's true. It is not a chronometer. As a matter of fact, I got it with another timepiece which is e real one, and only that (not a watch). I add a few pictures of my Chronometer / watch. no indication of a brand ...
I'm not convinced it is a chronometer, just because it says so on the dial. I think the two springs was a misunderstanding. -
I would cut my losses, keep it for parts. Buying a balance complete would be a Sunk cost fallacy.
