Thanks for the kind welcomes in the introductions forum!  Also for the advice, but now I must post what the problems are but no diagnosis and the causes.
I appreciated the information on what battery would replace the Watch Battery 343 which was on the last battery I had in the watch.  It would have been a mercury battery and those are no longer sold.
One kind soul suggested an AG 10 would work, and I went to Batteries Plus to pick one up.  They assured me a 389 RENATA is the equivalent and it's listed as a Silver Oxide 1.5 watch battery.  The dimensions were the same (diamter and thickness) as the 343.  I was excited to see if it would produce movement.  But it did not.  I also moved the hand with the stem but no movement happened.
I attached a photo of something I noticed about 25-30 years ago when I set the watch aside, which could be a clue.  There is a 3-pronged electrode inside the case, that sits almost flush to the inside atop what looks like gold colored mylar.  I suppose that's an insulator.  But, the electrode can swing side-to-side.  I moved it carefully to one side for the photo.  The 3-pronged electrode on the battery cover is mounted in the center.  It occurs to me that the electode inside the caseing could be the issue but I have no experience here.
I also took a photo closeup of the BENRUS case.  Two lines below the stamped name it is stamped "OPEN THRU CRYSTAL".
Maybe fools rush in where angels fear to tread.  I have seen watch crystal lifts, but don't own one.  I know I would need that and some tools to begine this.  It will of course have repairs beyond my newbie abilities.  ShouldI gather a few tools and learn now?  I'm not in a hurry and I certainly know a tool or tools is not part os the repair cost.  But if  buy the tools and treat this what like a medical cadaver to learn some things is that worthwhile?
And maybe, just maybe, I can bring Frankenstein back to life.
Mark
If that can slide easily side to side that's a problem. That your negative power contact That is supposed to go to the circuit board and should make a nice firm connection it shouldn't move.
Yes, it easily slides back and forth and when a battery goes in, I think as the case cover is screwed down, the negative power contact moves.  I suspected that was the issue because then when the cover is opened and the battery is removed the negative electrode has moved.  It also seems the negative electrode is more “flattened”, like there is no springiness to it.
Would you think it’s repairable by a newbie?  I suppose I need to disassemble and replace a component?
Thanks for looking and commenting!
mark
6 hours ago, HectorLooi said:
A 344 has the same dimensions as a 343. That's what I use in my Accutron 214s. Is this an electromechanical balance watch or a tuning fork watch?
I don’t know how to tell the difference.  I don’t know the model number. The face shows BENRUS Electronic, and I suspect it is a Citation Series from searches on Google.  But I think the model number or serial number is only seen if the watch is disassembled.
thanks for the info on the dimensions.
Mark
mark
Hi mf60. It does look like the contact has broken away. Was the watch stored away along with its battery still inside. If so there is a good chance some leakage of the battery may have also occurred.
While it probably is the 9154 it could be the 9150. Or might be one of the ones found at the first link you can pick and choose. But more than likely at the second link you scroll down until you get to ESA Dynotron. Unfortunately the ones in the pictures here have the battery strap which because of this case doesn't need this rap so we can't see the negative contact.
Then if you decide to service the watch I'm including the technical sheets.  9154 refers you back to the 9150 tech sheet which is why you need both of them. It also noticed that both of them have the exact same negative battery contact. Held in place with the screw that conceivably could be loose. The other problem is when was the last time the watch was last serviced? Watches of this type do not tolerate old lubrication a half be very very free to work otherwise they don't run.
https://electric-watches.co.uk/movement-gallery/
https://electric-watches.co.uk/movement-types/transistorised/
3540_ETA 9154.pdf ESA 9150.pdf
Mark
Some great help has come through  for you mate. Fingers crossed 🤞 it's a simple fix. But your first job is to get that movement out safely to see what is going on. That might be a task in itself  you're just starting out. I would think your first step is deciding if you do need a crystal lift to do it.Good Bergeons ones are going to run you 100 quid or so , second hand 50 if you are very lucky or cheap Chinese 20 quid and possibly a few others in between. So I'm hoping there's another way for you.
15 minutes ago, JohnR725 said:
Here's another source of information on the watch movement you have. If you look at the first page basically this is more or less the contents of a book on the website. Although it's much nicer in the book form than the website.
https://doensen.home.xs4all.nl/index.html
https://doensen.home.xs4all.nl/h1.html
Are you talking to me yet John ? Come on mate let's hug and make up. You know you love really, I know you do.
John. Come on behave, stop blanking me it's getting a bit silly now. I know you want to make up with me and you're frightened how our relationship is going to progress. I'll be gentle from now on I promise. I mean it I'll privately message you everyday, telling you how much you mean to me and that my world isn't the same without you in it. I'll write poems about you. If that doesn't  work you're going to have some explaining to do to your partner about all the chocolates and flowers I'm going to send you. Come on I know you've got a little smile starting to appear, come on let's see them pearly whites. Just a little one please 🙂
Wow that looks like some pretty complex stuff HectorLooi.  What is the copper  under the balance  wheel please ?
That copper thing is the drive coil. The magnet is on the balance wheel itself.
There is an awful lot going on In there. I wonder if it's worth all the effort for what gain ? Ok you don't have to wind it up, but how is it better than just a quartz set up ? Old tech for longer battery life ? Solar and Kinetic can last up to 10 years.
I am confused here?
What makes you think I'm ignoring you?
My fun in this group is sharing knowledge with people who need help do you need help? Okay to be more specific people who need help with watch repair I'm not a psychiatrist. Out of curiosity where is the current discussion that you have going that I'm ignoring on a problem you're having with a watch? But as a warning I don't answer every single question I don't even read every single question. Depending upon time availability of though through the list and see if I can answer any of the questions that no one else is answered. Or if I find the subject interesting or something that I more knowledgeable I will look into that otherwise I ignore a lot of things on this message board. So where's the watch that you're having a problem with so we can look into that problem that I supposedly ignoring?
Once again I'm being confused? Why am I being confused? Here's a question throw away watches Timex for instance or basically any of the pin lever mechanical watches never meant to be service sort of. Some of them do have screws some like Timex Have service manuals. But typically Timex servicing at one time they just used to swap the movements. So why is that their people on this group wasting their time servicing throw away watches? Could it be because that's their fun?  Because that is there fun they're not wasting their time there having fun why should we judge people for whatever it is they want to repair?
5 hours ago, HectorLooi said:
It's purely for diehard aficionados.
Isn't that what a lot of watch repair is about?
13 minutes ago, JohnR725 said:
I am confused here?
Hello John. I am so pleased to hear from you. No I'm not having  a watch problem at the moment, well I am but that's for later. And yes I probably do need psychiatric help 🙃. I was referring to two days ago , when you said you vaguely remember being scolded (that was me) and you said beginner's also need to be more tolerant. And I agreed. I was hoping you might have replied to me soon after. But now you're  talking to me I am happy 😊.  You have made me very happy this evening knowing that I have a very clever,understanding and humorous watch repair buddy. 🙂
1 hour ago, JohnR725 said:
I am confused here?
No I agree with you there, watch repair is fun, repairing anything that was made to have some use and having back as it once was is fantastic.  I was meaning what was the idea of having  battery power as well as a mechanical oscillator ?
The evolution of electric watches. Yes they started with balance wheels. But what about?
Kinetic
Were talking about a quartz watch with a rotor like on an automatic watch running a generator to charge a battery to run the quartz watch isn't that a little bit insane?
So the electric was a predecessor of the quartz then .
Kinetic has a longer battery life. 10 years as opposed  to 3-5 ? Rechargeable batteries as opposed  to non rechargeable
Edited by Neverenoughwatches
2 hours ago, JohnR725 said:
I am confused here?
Have you forgiven me then ?
No I don't think leakage occurred because I noticed that looseness many years ago and I kept the old battery in case I could ever find an identical.  I had stored the watch and battery for many years.  It would be interesting to find out when those mercury batteries were banned.  I doubt that I knew that battery had contained mercury.  It's stiing here next to me on the desk as I type it, next to the new RENATA 389 Silver Oxide battery.  The old battery is a Union Carbide WATCH 343.
I had already tested the old battery with my old battery with my ZTS Pulse Load tester but I tested both again and the RENATA 389 came up to 100% on the tester but the Uion Carbide was dead.
AS I recall that contac was loose many years ago and perhaps that was the problem all along.  It was stored with the battery in it for a while, after I noticed the contact issue.  That was many moons ago.
  • Similar Content
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
