Do Not Open, Bulova Sealed
Shane
I have never opened a drum marked "Do Not Open Bulova Sealed".  Does this look normal or did someone put something in it that they shouldn't have long before I got it.
Yes, it is a gooey as it looks.
The rest of the watch also looked as though it was used to mop up a past industrial accident involving crude oil rather than one of it's lighter distillates.  But not exactly the same as what's on the main spring.  Everything was glued solid with a dried brown snot of significant depth and viscosity.  I needed to pry everything apart.
I ran everything in the ultrasonic cleaner for about 20 minutes and it did absolutely nothing to it.  I then soaked everything, except the balance wheel and escape lever in acetone over night without much improvement.  After the acetone dried the goo has condensed down to a somewhat thinner but just as stubborn layer.  So... I'll try the ultrasonic cleaner again. (it reminds me of is very old cosmoline) Wash rince repeat.
But if the oil on the main spring is special (I'm not sure) I would entertain any ideas on how to proceed.
Thanks.
Shane
Edited by Shane
clarification
Well... Even if it is an intentional goo, it's certainly long past its "use by" date... I personally wouldn't worry about making it gone and just proceeding as if it were a normal mainspring in a normal barrel.
As for how to do so with the whole thing seemingly coated in thoroughly polymerized... whatever that is, run on down to your favorite FLAPS (Friendly Local Auto Parts Store), and grab a can of carb cleaner. And some gloves. There is a spray variety, and a bucket variety. The latter is more expensive (~$20 last time I bought a can), but stays contained a bit easier. It's nasty stuff so don't get it on ANYTHING you don't want completely absolved of all greasy sin, paint, general schmutz, or even dirty thoughts, but it is precisely intended to make that sort of residue disappear in a hurry. It's cheap, effective, and safe to use on most metals. I say most, because there are some exotic metal flavors in watches that I'm fairly certain weren't part of the test bill. Iron, aluminum, and brass are all sure to be safe. Oxide coatings on things like hair springs or screws may not make it out, but maybe they will... Black oxide is common in automotive applications... Which I mention because it's chemically similar to bluing if the hairspring or screws not pictured are blued. Maybe it's overkill, but you've already thrown some heavy weaponry at it, and it seems to have come out the other side unscathed...
2 hours ago, spectre6000 said:
goo, long past its "use by" date...
carb cleaner.
You're probably right about the oil in the barrel (right or wrong) needing to be freshened.  I have just never seen anything like that come out of a watch.
Hadn't thought about using carb cleaner.  I suppose it should work on whatever hydrocarbon or exhydrocarbon that was used.  I had already set everything in some fresh asetone for the night.  I'll reevaluate it in the morning.
Thanks, just looking for a sanity check.
You have to be careful when running things in the cleaning machine too long? If you're using ammonia-based professional watch cleaning fluids you definitely do not want to run for 20 minutes. As if you start going past about five minutes you could experience etching of the plates.
Then when you get super dirty watches like this even the professional watch cleaning fluids are  not going to clean that you have to pre-cleaned all of that stuff off because it just isn't designed to dissolve something like this. It also try the hairspring rinse solution for dissolving some of that.
Yes, ammonia is very aggressive and can dissolve/precipitate the tin out of the brass, then dissolve the copper.  The resulting substrate, even if dementionaly unchanged, is also much more brittle and prone to cracking.
I use ammonia for removing copper fouling from rifle barrels and would definitely monitor its' use.
It's strange that all the articles I've read about brass cracking from the use of ammonia are always related to the reloading of ammo cartridges. Many watch and clockmakers can testify that ammonia doesn't cause any structural damage to brass.
Maybe the stress on the cartridge walls from the expanding gases are way greater that what we experience in horology.
By the way, what happens when a cartridge ruptures while being fired?
The sharp and intense rise in pressure is supposed to seal the case to the clean chamber walls so gas leakage with small cracks should still be manageable. Poorly sealed cases against a dirty chamber is another thing and gases will escape at the shooter, a head failure on the other hand can be catastrophic to the shooter and firearm. Mercury fulminates (almost completely phased out) degrading the brass, over pressure and repeated over reuse causes an excessive thinning of the brass as it flows toward the throat (elongating the cartridge).  All should be managed or sorted out into the scrap bucket and the firearm should be cleaned.
Edited by Shane
    • Never. Good comment about the DIY thread. Yes I have seen it. Adapted a few thing to make my own systems of cleaning.  Adam and Gentlemen are my 'go to' for inspiration. I only have about 18" by 18" as my working area for cleaning. I have adapted. This is my system.   After disassemble and checking I begin the clean with pegwood and lighter fluid. Fiber brush if needed. Everything , except shellac items, balance bridge and pallet fork, into lighter fluid jar. Large items at base and others into baskets. Jar into ultrasonic warm water. 3 x 2 min. Balance and Pallet in small tray and lighter fluid dripped and allowed to gently clean. All blow dried Everything from jar moved into 2nd jar containing Isopropyl alcohol. Ultrasonic 3 x 2 min.  Balance and pallet dripped with Alcohol for under 1 min. Everything out and placed under nail blower for 10 min. Before assembly I recheck all parts for damage. This is when I make my decision to order parts as I can see what needs to be done. My system in now pretty good. Well, at least for an amateur.
    • Looks good, maybe a little complicated to put together. So certainly some effort, time and headscratching involved if you're not particularly tech savvy. Personally i like the more simple approach of diy cobbling, you dont end up with anything automated so the cleaning operation is a bit more hands on. But you have something simple, cheap, less to go wrong , easy to fix if it does, but in essence cleans just as well. Look at the diy watch cleaning thread Ross, there are some simple ideas in there if you feel you want to make something.
    • So you need a 3d printer in order to have this. I wonder is the other parts that you need are available say in the UK because that is where I live. It looks a nice cleaning machine.
    • The case style and the movement are in the style of American. If you take it apart you will need mainspring clamps as the springs are strong and very long
    • Lol!  Not even close! 😆  It's a Sam Hueng movement.  A Korean firm.  So I think this is post-war, 1940-1960?  Maybe pre-Korean war since it doesn't say "South Korea?"  The chime side winds clockwise, but the power side winds counter-clockwise.  Looks like someone has been trying to wind the power side clockwise for who knows how many years and the spring was been unwound to the state you see in the pictures.  It doesn't seem damaged though, and I was able to wind it in the correct direction.
