Hi everyone
I started watching lots of youtube watchmaking vids during covid lockdown to get away from the horror and unbearable news that was unfolding. I'm in my 50's and had a fairly scary early encounter with covid, coming down with it a few months into lockdown as my daughter, who still lives at home and works in the care sector with elderly people, was exposed to it due to all the hospitals discharging patients back into care without thorough checks first. People like 'nekkid watchmaker' and 'wristwatch revival' really helped me to get through, with their love of the craft, natural enthusiasm and gentle humour, in a subject that was a million miles away from the 24/7 covid news misery.
I took one of Mark's courses which was excellent and very easy to follow. I grabbed an ETA 6498 (seagull variant) and tried to disassemble along with the guide. I had such problems with one of the shock springs, eventually losing it, along with the jewel, "somewhere", that it quite disheartened me. Things then got really busy with work for quite a while, and while I carried on watching and enjoying my youtube subs, I left the ambition of watch tinkering to one side.
I think I'm ready to have another go as a while back I bought another whole seagull movement because I couldn't figure out how to buy the new bits – I would have asked for help here but couldn't join this forum for some bizarre email related reason, but thankfully that's been resolved and here I am, saying hi!
I'm frankly scared half to death that I'll just ping another part into oblivion. I'm sure some people won't understand faltering over such a thing, I'm probably just not blessed with confidence on this sort of micro-scale operation, maybe it's because my vision isn't what it once was. I don't seem to have this sort of a nervous issue with almost anything else!
Reading all that back it all sounds a bit of a downer. It wasn't meant to be. Quite the opposite. I can't tell you how much I'm fascinated with the mechanisms and procedures, and I'm very grateful to those who put such great content up - it does way more good in the world than just teaching people about watch repair and servicing.
Anyway, hello! And thanks for letting me get that off my chest 😆
Edited by DigitalM
grammar!
2 hours ago, DigitalM said:
People like 'nekkid watchmaker' and 'wristwatch revival' really helped me...
Welcome to WRT @DigitalM !
Those two guys probably are responsible for me being here.
I'm stalled partially through my first watch movement restore due to waiting on oils and tools (all of which should be on their way). Hopefully you'll decide to find a real watch that you'll take on as your first restoration. I decided to skip Mark's walk through and dive in. I have a 2nd grade 313 Elgin in the wings in case things go horrible with my first and I have a Buren 10.5 Grand Prix on the way.
I keep hoping that I'll find something amazing on eBay for cheap that will allow me to wear something that I brought back from the dead that I can be proud of.
Welcome to the forum @DigitalM
Don't worry about your post and how you think it reads. I have done it as well and I was only looking at doing clocks. Not the microscopic world of watches yet.
It is very easy to forget that you are watching a watch be repaired and it is filling a 14" laptop screen when in reality that enormous picture is actually only about 32mm across.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
