I'm not actally any handyman, I hardly can repair my find, but  I was interested of the watch as she just runs on her face. Found some answers for that symptom already,
but I am a little further away: I cannot even open the timepiece! It has a place to bulge, and I did, with my fingernail! and yes, it opened easily.
But from the face-side. Cannot find any clue where to open the back. Visodate there just for comparing them.
That is a front loader case and your is the most frequently asked question by beginners, enter "front loader" with double quotes in the search box top right. In short, it is opened removing the bezel and lifting the dial while rotating the crown to free up the two piece stem. I recommend against owners trying that without proper tools to avoid damage.
I don't understand your question. It looks like you have already managed to opened the case of your watch in the 2nd photo.
Do you mean how to remove movement from the lower caseback?
Like the title says, the OP is referring to the white dial watch, on the left in 1st picture.
Yes, cristal is open, but I hardly can now see why it is not running while on its back. Actually I can see as much while cristal on its place 😉 -so, I'd like to see more of the inner flesh of the piece...
To 'see' that it needs to be looked at with the eyes, tools and knowledge of a watchmaker. One possibility is a broken lower balance, especially likely in mov.t w/o shock protection. Of course the mov.t must be fully removed from case as I have shortly explained above already, and lot more details in the topics about 'front loader'. When it come to watches it's not about being 'handy' as in changing a car tire, it takes a lot more.
I think the one on the left is a Tissot which the OP used for comparison. The watch in question is the one with the 2 piece case and caseback.
The lower caseback is like a tin can with a slot cut out for the winding stem. Usually it is loose enough for the movement to be pulled apart by holding the caseback in one hand and the dial in the other. Sometimes if it is really tight, some prying around the dial with a case knife is necessary.
Hector says it best.  If Oskuk means the watch on the right, then it would seem to be fitted tightly into an enveloping "dust proof" case back.  It surrounds the movement, and the movement sometimes must be gently pried up and out.  And sometimes, old dirt and grime can make that difficult.
Well, whatever the case, the fact remains that even with the mov.t fully exposed is practically impossibile for an owner to diagnose, and much less repair, a watch that doesn't run in all positions.
If there is a slot cut that means there is no pendant tube, and no water resisitance at all, which makes a very poor construction. Instead, these are in fact classic front loader cases, with a two pieces stem that must be separated (and rejoined) as I tried to explain before.
2 hours ago, Oskuk said:
Yes, got it, dropping to metal bin. The Tegrov, not Tissot.
Why. That is a nice watch, give it a chance in the hands of someone else. Like 5 Euro on Ebay, or gift. Maybe it's just me, but I can't throw away a watch, or anything the like.
On 4/12/2022 at 8:57 PM, Klassiker said:
You know this is the Watch Repair Forum?
Sure have to settle just watch, far.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
