We already have a Facebook group run by Mark , so this is a bit moot. Search for “Watch repair lessons” group. Tom
@dibs1 Hopefully you see this and post an update. @Knebo Would you happen to know what is the end-shake tolerance for a cal 15xx rotor or is there such a metric? Also, is there a specified height of the rotor? I got the watch serviced which addressed the rotor grinding against the base plate and case back (i have checked by moving the watch in a circular motion to spin the rotor and have tested it dial up and down) however whenever the watch is shaken lightly the rotor touches the caseback and makes a ding. What is unusual is that is only happens when the rotor is resting at the 9'o clock position. The axle was replaced and reading around it seems that spring clip, jewel and axel are the three parts that individually or together are causing this issue.
Yes, barrel size. A 11mm spring will push out into a 11mm barrel, no need to go 0.5mm smaller. -
Hello All, I’m looking for advice about how to interpret the mainspring specs described in the GR documents and in the catalogues of online sellers such as cousins. My problem relates to interpreting the value describing barrel size - I’m unsure what the last number REALLY refers to. For example: 1.10x.0105x360x11 (This refers to GR2628-X) Does the “ 11 “ here refer to the barrel inside diameter of the calibre OR to the diameter of the wound mainspring before insertion? For example if my measured barrel inside diameter to 11mm, I would normally select a wound spring size a little smaller, say 10.5, wouldn’t I? Or, does the barrel diameter described in the catalogue specifications take that into account and I would therefore order a catalogue size 11 for an 11mm barrel ID? Hope this makes sense. I can’t find clarification of this anywhere. Many thanks for any enlightenment. Cheers, John
By nickelsilver · Posted
Let's say, like in a watch, you have a 70 tooth 4th wheel, which needs to make a turn in one minute, with an 18,000 beat escapement. 15 tooth escape wheel as usual, and a 7 tooth pinion on it. 70 x 15 x 2 / = 300 That's 300 beats, and there are 5 beats per second, so divide and you get 60s, one minute- all is well. If we do 70 x 15 x 2 / 8 that equals 262.5. With an 18K balance, which will let the escape wheel move one turn in 6 seconds, the 4th wheel will have made like 1.14 turns. So the time display is running fast. But this comes to like 7.5 seconds over per minute, which is about double your gain (maybe I'm wrong- I'm mathing on my phone while writing on my phone 😄) but pretty sure the gain is more than you are observing. A possible culprit is that crown/4th wheel isn't running true, and a tooth is slipping past a pinion leaf once per revolution. I've seen this. If the platform is original and it's a nice piece they are often pinned, so the depthing isn't an issue. If the platform isn't pinned, check the depthing. And at any rate check the crown wheel between centeres and make sure the teeth are running true.
