Timex M24 fast
1 hour ago, JerseyMo said:
have a look here - https://heritage1854.com  for more Info on movements.
black seconds hand...no problem I can list under my seller id.
Timex used a small brass wedge pin to keep the end of the hair spring in place.  Is that missing?
JerseyMo no the wedge is  not missing. I was looking for a confirmation of design. How is the spring attached to the adjustor? It reads as if the spring is kept lets say in a hole in the adjustor and just the spring tension keeps it there.
List here on this forum or Ebay using your seller id?  thanks Bob
Alright got home after work and got to work. Removed spring wedge and balance wheel. There was a hole through the top plate where the back end of the wedge could be seen. Using a small screwdriver as a pry bar against the side of the hole the wedge came out.
The bearings and bearing pivots look good. I did sharpen a toothpick and dipping into alcohol cleaned the bearings.
The balance wheel and hairspring got rinsed three times in solvent. The spring definately looks cleaner.
I ordered three precision oilers which might help for oiling the bearings. When the time comes to peg the hair spring a tiny pushing bar with an opening to receive the end of the wedge would be nice ensuring no slipping off the peg while inserting.
Will review with our lead model shop friend.20220401_172720_copy_747x1328.thumb.jpg.d28934465876f8938758c807669e99ca.jpg
Keep us posted on the result
Watchweasol one thing I have learned is to not use aerosol contact cleaner with lubricant. Having oil everywhere does not help with the battle.
Very true lubrication needs to be put where its needed and only in controlled amounts. Starting with a Timex is a steep learning curve because of their construction, so well done for getting it back together there are many who would not attempt it in the first place
There are two things that I don't understand.
Firstly, why did you use contact cleaner on a mechanical watch? Contact cleaner is only used on Timex Electric/Electronic watches.
Secondly, contact cleaner may appear oily but it evaporates eventually. After all, you wouldn't want oil on an electrical contact to catch fire.
HectorLooi, I restore, collect, and flip antique/vintage audio vintage hifi gear. There is contact cleaner for on/off style switches and there is contact cleaner with lubrication for sliding resistive type switches (potentiometers). Thought process was the cleaner/lubrication is in a solvent based aerosol spray and would penetrate and get to places that is not accessible without teardown. I just expanded my interest in mechanical watches couple months back. What I thought was an easy way out to lubricate a watch has gone out the window. Bad Idea!
Hi we are back to the point where the spring needs to be made longer. Is there any excess balance spring protruding from the back of the pinning point if so by slackening the wedge and pushing the spring in  it will make it longer and effectivly slow the watch down. Making the spring longer in the round will also put it off beat so that will need to be adjusted, with out some method of deteting the beat error ie Timegapher or the like it will be difficult, a matter of trial and error which is time consuming.
Its a possibility have you not done that already ?.  Have you chesked that when the coils are vibrating that they do dot touch and the spring vibrates between the sides of the regulator and does not hang on to one side or th other.
no I do not have a demagnetizer. I just started playing with the Timex's a couple months ago. I just checked a demagnetizer can be had on Amazon for $12 or so.
You said " Have you checked that when the coils are vibrating that they do not not touch"......so watching the hair spring while the balance wheel oscillates the coils should not touch?
You said " and the spring vibrates between the sides of the regulator and does not hang on to one side or the other"
is this observing the spring within the slot in the adjustor which the spring runs through?  The sides of the regulator is the sides of the slot cut into the regulator which the spring runs through? While observing the balance wheel oscillating the spring within the slot in the adjustor should touch one side of the slot during half of the cycle and then touch the other side of the slot during the other half of the cycle??
the Timex M24 service manual states that the hairspring should be in light contact of the inside edge of the slot in the adjustor through out the entire cycle of the balnce wheel.
2 hours ago, JerseyMo said:
items listed and message sent
thanks Jersey....may hold off until I can determine why the watch is running fast.
Under normal circumstances  a watch spring beats within the regulator, Timex were a law unto  them selves so if the manual states a light touch on the inner side so be it.  When the coils beat they should be free with no interfearance if the coils are touching  and not flat  it has an effect on the spring  which could cause your problem
Okay got home after work and inspected the hair spring closely and lo behold the two most outer coils were touching. So I stopped the balance wheel and oh so very carefully separated the two coils and they stayed apart.
Have been monitoring the watch and I believe the watch is not running fast. Will continue to monitor and check in the morning. But am confident that it is not because I would note after a couple hours that it would jump a minute and it doesn't appear to do that now. Very excited thanks watchweasol for the insight on inspecting the hair spring after installation .
4 minutes ago, HectorLooi said:
Could it be that your regulator is stuck? Try putting a drop of oil where the regulator is riveted to the plate and work the regulator left and right.
HectorLooi I think we got it. Thanks
    • Ross yes we all love the forum and yes a lot of these facebook groups are awful and will never compare to what we have here. But facebook is exactly what you make it for yourself, some let the world know what they had for tea and if they threw it up again lol. It took me years to enter into the realm of facebook and 95 % of it i ignore completely,  i use it to my advantage, I'm not an addict of it like most of the world is. My profile contains absolutely nothing about me, its not even my real name, all it is for me is a vehical for me to access information, if i dont like what i see i ignore it. You develop an attitude of indignation towards the vast majority of it.
    • No, It's still showing the "20 Micron" between the lugs.
    • Thanks for the replies.  @Neverenoughwatches  If you have something that looks suitable, let me know and I'll get some dimensions.  Thanks.
    • Thinking.  Mark has said he would be here for the foreseeable.  I have looked at other watch forums. One will not let me join as my 'browser' is not set? Another feels very complicated. Another has showing of collections of Rolex etc, all vying to show what they have. Not what they do for watch servicing. And, the criticism of others is so prevalent.  I asked a question and received, "Read a book more often" as a reply. I was given advice and constructive criticism by members, who advised the book, but realised as a result of my dyslexia, my difficulties. And so spent time assisting me.  I like and enjoy this forum. I am at 2 1/2 years into my self imposed 5 year apprenticeship. Averaging 10 hrs per week. I can do virtually anything that needs to be done. I still lack some tools. DIY skills makes a lot of things available to me. Someone made the comment about 'Facebook'? Open my life for the inspection of others? No thank you.
    • Come on chaps i need some ideas, i have the right staff for the movement, i can probably make up another hairspring and balance wheel with some effort involved, which might not run time accurate but i can deal with that. What I'm really stuck with is an oversized roller hole to fit onto the staff. I cant make a roller, so i have to make this one fit, which is looking like a fastening in repair with adhesive.  Getting the staff in centrally is going to be difficult, I'm guessing the space around the staff is about 50 microns. My other option is to track down a different staff with a better roller fitting profile but match profile sizes elsewhere,  or another correct roller, I'm sure this one has been broached out. It may not even be the correct roller, the staff sits really low inside it. I could just rodico the roller on and then test to see how it interacts with the fork.
