Spinning Hands
Willow
Hi all, any advice after this single train platform escapement was working then all of a sudden the hands started spinning round, nothing else .as far as i could see thought it might be the clutch but that seems ok. Thanks
Are you sure you have the depth of the contrite wheel correct? The way of telling this is the movement should still work no matter what angle the movement is in, it should still work up side down.
It sounds as if it is more likely to be the pallet stones as already mentioned.
I can think of a senerio for this,  pallets moved after running for a while due to shelac having been lost during the clean.
movement was only cleaned in warm water and the escapement wasn't cleaned at all just oiled
9 hours ago, watchweasol said:
Hi Willoe  Is it possible for you to remove the balance and a close up of the pallet and the pallet stones.     cheers
Hi watchweasol yes will do in this photo the arrow pointing to the screw i did remove that what is the signifinance of that screw, thanks
53 minutes ago, oldhippy said:
Here's a thought. The center wheel is friction tight I believe held in with a pin that fits in the recess of a spring on top of the center wheel, has the spring worked it's self out part way or all of the way.
Hi oldhippy all i can see is the center wheel has a clutch with a pin through to hold it in place see photo at start of thread do you mean that thanks
5 hours ago, oldhippy said:
Yes that is it. As I said I wondered if the pin had worked its self out as that would cause the hands to wiz round.
checked the clutch it's ok watchweasol wanted some photo's of the stones just going to do that now
Just now, RogerH said:
Am I missing something? Where's the pallet? this should be where the two pallet stones fit? Rocks between the Balance spring and the Escape wheel...has it pinged off?
Me too somethings missing. The escape wheel will just run with no control.
Is this it the photo you want
Hi Willow  I am still of the opion that if you remove the balance complete and expose the pallets and escape wheel you will be able to inspect the interaction of the pallet and the escape wheel locking or not locking as may be the case. the other thing is the engagement of the contrate wheel whick Old Hippy mentioned earlier. If you have bad engagementit could ruin the platform amd the wheel. An other point to check is the contrate wheel tight on its pinion and not slipping.  cheers
yes the interaction with the pallet and the escape wheel is not right the escape wheel is just rocking back and forth when i set the balance wheel in motion never worked on one of these is it easy enough to take apart
    • The entry and exit stones have different impulse face angles  murks.
    • Depending on how much of the screw is left, you may be able to screw it further in and it may fall out of the hole that the dial foot sat in. To do this I rough up the tip of the good screw and screw it in, often the rough surface of the good screw and the rough surface on the broken screw get enough of a bite to transmit the torque into the broken section and force it out the other side. Like I said the size of the broken screw needs to be in your favor, but you never know you may get lucky.... or if you get it moving you may be able to then back it out with a screwdriver taking a bite on the rough surface. worth a try
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
