Help with chiming mechanism on Seth Thomas quarter hour!!!
I have seen more glued ones like this than I can't stand the sight of. Good clean isn't easy on this and let's hope no glue has run down to the hole jewel chaton.
Need to search for the calib NO. Give it some wind and check the frequency on TG, Greard Preguaux put some 36000 bph in there watches , developed the 36000 beater in colaboration with zodiac and enerhart Fortis & bunch of other guys. If this is a 36000 beater its collectable, the first 36000 beater built, as the higher the beat the more accurate is the piece and Definately a keeper.
The springs I talk about are long strips of steel sheet, they have suitable shape to make the verge. You will need just to bend to shape using the original as template and then cut and grind the tips and drill holes for the bearing rivet and the leader. -
Brand new from Cousins. The balance wheel is a totally different size, too big to fit the movement. Tried transferring the hairspring to the original balance, hence the rapid gain. Yes, all screws fitted and the balance setup properly in beat.
