Hello,
I bought a Jacot tool (yea!).  It came with this ring thing.  Does anyone know where it goes and what it does?  Many thanks.  Arron.
1 hour ago, arron said:
Hello,
Don’t think this is from the Jacot??
What? . . .  Well if I keep buying watch repair tools I'll eventually buy the tool this was meant to fit.  Mystery over.  Thanks JD.
That's a safety guard for Jacot tool. It helps especially when burnishing conical pivots with long conical portions; it can be set so that the burnisher makes minimal contact with the conical section. If too much pressure is applied to this area the risk of breakage goes up. It can be useful too for straight pivots where the difference in size between pivot and and the next diameter is very small (dial side of many center wheels comes to mind). It helps avoid accidentally riding up onto the next diameter.
Whether it fits a given tool or not is another issue. All of my Jacot tools are Steiner, and they use 8.8mm diameter runners. There were numerous makers though, and certainly different sizes. It doesn't have to be a perfect fit, but does need to stay in place without shifting.
Edited by nickelsilver
That's a new one on me. Mine never had that part there was no indentation in the box for such a thing. Mine was handed over to me from my master.
I've never owned one, but seem to remember there was one at school, and it's in Daniels' book. I've owned probably 15 Jacots over the years, and none had one. So pretty rare.
13 hours ago, arron said:
Hello,
Actually yes, I know that one. It is a pivot stop/rest.  It is intended to go on the end of the runner that has the grooved shelves (no need for it on the lantern end).  I don't use it often; only on much larger staffs.  It acts as a rest to keep the pinion from jumping off the groove when you're burnishing on the draw stroke and bowing away from you.  As Nickelsilver also pointed out, it reduces risk of breakage too.  I have not yet had to burnish conical pivots, but I could see using it for situations like that.
I prefer to rely on technique.  But the larger diameter staves (think 18s) are harder to keep in the grooves, I admit, so I have used it a few times.
Edited by KarlvonKoln
I hope everyone is having a good weekend.  I appreciate the additional information you've provided.  I have two questions.  1) Did i put the ring on correctly? (see yellow arrow).  It seems like a person couldn't work on the pivot with the metal flag in the way; or maybe if the staff very long the flag could go further to the left opening up a space for doing the pivot work.  2) The jacot is a complete set but most wheel pivots in a couple of pocket watches i tried will not fit into the right-side spindle indicated by the red arrow.  The escapement pivots and balance wheel pivots did fit.  What does a guy do with the other pivots?  Can you buy those spindles with larger openings separately?  What is that part called?  Or do you guys just use a lathe for the larger pivots?  Thank you.
Did you try to reverse the spindle? Most have two usable ends.
Frank
Thanks for the reply Frank.  I did try both ends of that spindle.  To my magnified eye they seem almost the same size; neither of which is big enough for any wheels other than the balance and escapements I've tried.
    • Funny I should come across this particular thread because I have a hairspring that I’ve just knocked the collet off!! It was too loose on the balance wheel and I was trying to tighten it (of course I failed!).  So I’m looking for a new balance myself. The hairspring is in quite good shape but obviously doesn’t have a collet now, so I don’t know if you’ll be able to use it. I wouldn’t dream of trying to refit the collet myself because I know exactly what would happen!! If I wanted to refit the collet to the hairspring (assuming I can find the original as it’s on the floor somewhere!!) where would I find a taper pin small enough? As some of you may know, this whole thing is tiny!!
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
