ETA 2789-1
Aaagh! Can you believe it! I'm missing one cog. Everything was going well. Then, cog to hour wheel is missing!!!. As this was my first opening of a watch in January, I wasn't as careful as I am now. Not giving up. The watch is still working. Happy bunny on that level. Looking for spares.
Will keep you posted
Regards to all.
Ross
  • 11 months later...
15 month into the hobby.
The ETA 2789-1 is the movement that I started with. I've had my trials and tribulations with it. However I am now well into the hobby and understand how little I know, but have gained enough knowledge to appreciate that fact. Back to the drawing board. I've done a complete strip of the movement and will commence a rebuild. I am fortunate I have 3 donor's to chose from. Going to take my time and apply all the little I know. Still really enjoying the hobby.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
