  • Michael1962 changed the title to My new (well to me anyway) Emco Unimat 3 lathe and mill and lots of bits
Well, considering the AU$2,200 paid looks like you will be all in with small (but not really watchmaking) machining. Look forward to see what you will be doing with it, have fun!
I'm hanging out to see it. Has been a long time since I used a lathe or a mill. And they were a darn sight bigger than this one.
Andrew dropped it at the depot near Moss Vale in NSW on Tuedsay. So hopefully sometime next week.
So I got an email today. Due to Covid, my delivery might be delayed. Why? Are the trucks going slower?
Got a tracking number. Awesome! I'll check and see where it is.
It is 'In transit.' Of course it is. Not where it is, which they should know, but 'In Transit.'
Where else would it be? Pretty pointless tracking facility.
So do I. I'm really excited about it.
I've already started to build a bushing rig in my head. I have a few ideas.
I saw a mod that one guy did to his mill post to assist with keeping the head in line when moving the mill body up or down the post. I am not sure if that is necessary really as I think you have 50mm movement in the spindle once the body is tightened? If you can't get it all done with 50mm of movement, I think you need a bigger mill.
Edited by Michael1962
So I had the tracking number for my crate and when I put it in the app 3 days ago , it said "Delivering". I took that to mean that it had reached the depot and that they were logging it in etc. After 3 days of "Delivering", I rang. "You're crate has been waiting for you to collect for 3 days sir." Hmmm. Went and got it today. Apparently "Delivered" which was the next step on the tracker is not when the receiving depot has processed it for collection. "Delivered" is for when I have collected it.
Anyway, when a crate becomes art. I mean he even made handles!
And the crowd fell into a hushed silence as the lid was unscrewed.
And the crowd went, "Ooooooo....."
And then after removing at least half of the package weight in screws as well as all of the associated timber and bubble plastic,
Is it politically incorrect to call a metalworking machine cute? It is bolted to the drawer that you see it sitting on in the bottom of the crate. All of the bits and pieces are in there.
I knew it was going to be small. It is quite possibly smaller than what I thought it might be. The chucks on the lathes I did my apprenticeship on weighed a lot more than all of this.
Condition? Immaculate. It really is. I will have to be careful as I have 'rusty' hands. I think I will either have to have oil handy to clean everything down after use or wear rubber gloves when using the lathe and mill.
I could not be happier. Oh, okay. If I won millions in Lotto, I would probably be happier.
Chuffed? Absolutely. 🙂
It was worth waiting for, glad you have got what you wanted. Now the fun and games start working out what does what and where it all goes. If you are not sure about using the cutting tools start on something soft such as brass. Don't forget to take some photos and upload when it is all set up.
I don't think it would have been packed this well from new.
I have the books inside now to read through. Have a bit of cleaning and reorganising to do in the garage to be able to put things on my workbench. I may have to rethink my workbench as it spans a fair way from the front to the back and while the sheeting I have used is heavy enough, the timber I used underneath it to hold the bench flat has allowed it to sag slightly so I have a bit of work to do.
Well the original workbench in there has been scrapped. the legs from it have been repurposed as the legs for a really thick tabletop that we had. I have sawed the front edge and the back edge of the top off and have started setting things up. Have a bit of rationalising to do to get things finished off. got some ideas. I unfortunately didn't take any photos lately.
I used the lathe today! Put the 3 jaw chuck on to hold the drive shaft from an old (but really good) Hanimex fan that I am cleaning up to be a workshop fan. I used it tiling for a fair while and the fan was filthy. I had a lot of trouble getting the screw out that held the oscillating on/off knob. Ended up having to drill the head off to get the motor cover off so I could clean everything up. Worked on that today and finally got the end of the screw out. Now here is the bummer about that. The screw was a left hand thread. Didn't see that coming. If I had tried the other direction to undo it, everything would be fine. Not sure how I am going to go getting a metal thread screw that size in left hand thread. I'll probably have to make something. The easiest thing would be to open the female thread up a bit, tap it right handed to an available screw. Little bit of loctite on reassembly.
This thing would be over 50 years old. Steel wool on the chromed fan guard and it is coming up silver everywhere. Things aren't made like that anymore.
My old bench top is going to get cut up to make a stand for holding 2 or 3 long case movements for testing. Not sure how much I'll get out of the sheet of ply. It is 19mm thick so would work well.
Slowly getting set up.
So I needed an insulating spring end for the Hettich clock.
Started with the plastic hook from a budgie bar that our bird had finished. Cut the large flat end off with about 10mm  of the centre part and put it up in the four jaw chuck. A lot of people think you can put most round things, black round for instance, up in a 3 jaw chuck. You shouldn't. You should mount that up in a 4 jaw first and turn the first end to round. That end can then be put up in a 3 jaw chuck.
Turned the centre part to round and just a bit bigger than the spring inner ID. Turned the part around and put it up in the 3 jaw. Turned the large flat end down to the diameter that I wanted. Then turned the part around again to hold it on the larger diameter and machined a 1 degree taper onto the smaller diameter so that it screws into the spring.
And all of that for this.
  • 1 year later...
Hello? Although this chat appears to have ended over a year ago I wonder if anyone may still be listening? I've recently inherited an 'emco unimat 3' mini-lathe that belonged to my father and well...I know nothing about it other than memories of sitting on the workbench while my dad tinkered away on various projects. Its been sitting for some time and needs a good clean up, new belts, possibly more - I'm just spurting out buzz words here....I have no idea about any of it. I do know that all the parts still move in the directions they were intended and it travels with a ginormous case of cool wiz-bangs and twirly parts.
I've tried listing it for sale twice now and each time couldn't seem to push the 'list it' button. It seems like something I could learn and put to use but even if not - I feel the need to give it some attention before releasing it back into the world. Which lands me back at my original problem...I have no idea what I'm doing or where to start. You all seem like a knowledgeable and supportive group - any suggestions?
I have the Betriebsanleitung Instruction book so I guess I'll start with learning German. Any advice, guidance or 'atta girls!" are appreciated.
Cheers,
Nicole
I have two unimat lathes one with milling attachment. They are very good for clock making. Accessories can be bought on ebay but can be expensive. How about posting some photos of what you have and I might be able to help you.
I'll chip in with whatever I can as well from my background as a fitter & machinist. I have done some things on the lathe and have found some of its limitations, but for what it is meant for, it is a great little machine.
As @oldhippy has said, post up some photos and we'll give you what help we can.
Lathes are a very useful machine when you know what they can do.
What bearing oil do you use please OH ?
  • 11 months later...
So I went to use the collet holder on the lathe to finish off the new pivot that I have made for a quartz movement.
Why, you ask when quartz movements are so cheap. The challenge.
Anyway, got the collet out that I wanted to use. Put the collet holder on the lathe, collet in and tightened the collar to see how it all went. Uh oh. Everything goes tight with the collet nearly 5mm from the end of the collar. that isn't right, I say to myself.
The cause.  Looks like a washer that is trapped at the bottom of the bore on an angle. It is actually all one part and something has gone wrong when it was being machined. I would suggest that the previous owner never used this. There is no brand on it so it may be a cheapie.
Anyway, the setup. I did try to initially set it up to use a tungsten carbide tip boring tool that I have, but it didn't have the length that I needed to get to the bottom of the bore. So HSS it is.
Part of the way through the machining.
Machining finished. Didn't need to take the bore diameter all the way to the other bore diameter. Did need to face off the internal face at the top of the collet taper though.
The collet collar removed from the lathe before I took it off the facep[late.
And the final result. I now have a usable collet holder.
I'm really chuffed that I still have a skill that I learnt a lot of years ago.
Sterling job Michael 👍
Ta. I'm very happy with the outcome.
I'll put the holder back up on the lathe spindle tomorrow to see how true it runs.
I'm trying to decide whether I need to get myself a small dial indicator with a magnetic stand.
I set this up by eye.
I forgot to mention, turned it at about 500rpm. Something like that. Dry as well as I need to get hold of some cutting fluid for when working on steel.
Brass isn't really an issue. Might get a better finish with a cutting oil.
Well I have successfully drilled out the pivot on the impulse gear on the quartz movement, used the fixed collet holder, made a new 0.6 x 8.5mm long pivot which I then glued into the impulse gear. Put it in the movement cover with just the coil to check it all worked ok. Clock is now ticking away quite happily and hasn’t missed a beat. Actually quite pleased that I worked out that the piece of the pivot that was in the magnet side of the pivot was to engage the spigot on the respective movement cover. Just mechanical fitting on a completely different scale. 😊
You're doing cool stuff Michael,  your converted workshop is starting to reap good things....so pleased for you fella 👍
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
