Just brought this pocket watch off ebay noticed the screw for adjustment either fell out or is broken make is mineva 17 jewels can this part  be sourced and is it a easy fix to do for a novice or is it best to go to a professional.ps i know in picture it shows screwCC2152C5-BB3C-427E-9129-9177764D6A1B.thumb.png.6117a65f564e55b4f096b49b4cde147d.png
If you're talking about the screw that has holes through the head and presses on the regulator, and it has gone missing, first give the watch a good shake over a large table back open movement side down. It's probably in there. In the pic it looks like the regulator is at the end of its spring tension, so it may have wiggled out in transit.
You might find a replacement in a donor watch, doubtful you'll find one at a supplier or screw assortments. In my boxes of 10s of thousands of screws I haven't seen one. I have made them though, and it's definitely trained watchmaker territory (whether amateur or pro). It's a long screw, fine thread, small diameter, and putting the holes in well is a challenge too!
19 hours ago, JohnR725 said:
Which adjustment are we talking about?
Rate regulation. Most watch owners don't know the difference either. Also, it would help if in the future posts the OP title is about issue at hand.
You can show us the boxes if you want. Just not the rest of the lab please, there is a limit to what an average hobbyist can take.
Another item on my list. I like to make screws and related jokes.
8 hours ago, jdm said:
Rate regulation. Most watch owners don't know the difference either. Also, it would help if the OP could title with something related to the issue in the future.
The reason I asked was that?
The missing screw seems to still be in the picture that's what was puzzling me? Sizing and maybe there are some other adjustment that I wasn't aware of that is missing?
Per OP:
I know in picture it shows screw
You have several options here one you can just remove the entire micro swan neck regulator part. Then you have a standard regulating arm like any other watch and you can still regulate your watch.
I can't tell if your screw is long enough if you could remove the broken part of the screw which can be a pain at times last one I did was rusted inside needed soaking in penetrating oil.  If you get the broken part off you can see if your screw has enough threading they might still be able to regulate. Otherwise you look on eBay people are selling these I doubt the Swan Part is going to fit as I doubt there is any form of standardization but if you're lucky maybe the screw will work.
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
