As the title states....what is the best tool to use to remove the crystal with a metal rim around it without damaging or scratching the watch case or the crystals metal rim?
If the is a special tool that is used (or does one even exist?) could you post a picture of it?....recommend where to purchase it?...etc.
Any an all suggestions, opinions and or recommendations are welcome.
Thanks in advance!
Thanks in advance!
This press:
https://www.cousinsuk.com/product/press-robur?code=G0728
with this set:
https://www.cousinsuk.com/product/die-set-robur?code=D0425
is probably the best, but expensive. They are cheaper second hand on ebay but not by much if two bidders are keen.
Plato thanks for your post though I do not need that since I already have a press & die set.
I need the opposite of that.
Again, I would like to know "how to remove the crystal with a metal rim wrapped around it"  that was previously pressed into the watch from above (using the press & die method).
It looks just like this:
760735753_THEWRIGHTwatchCASEFRONTcrystalwithsterlingsilvermetalring.thumb.jpeg.df38e352d7f618d6300abd5927f3b9c6.jpeg
The watch movement is set into the case from above and in order to replace the dial's hands the top crystal needs to be removed to gain access. The movement is not designed to come out the back.
There is this tool that I just happen to find doing an online search.
https://blog.esslinger.com/how-to-remove-a-watch-crystal-with-crystal-lift/
...and then there is the following method below but I am real hesitant to even think about going that route?
https://blog.esslinger.com/how-to-remove-a-bezel-fit-watch-crystal-with-a-bench-knife/
Edited by Orhorolgy
Ok, I thought you wanted to remove an armoured crystal. To remove a bezel, just a regular case knife will do the job. Upload a photo of the watch just in case it's something unusual.
If you are paranoid...as I am often in these situations...use a safety razor to start the process of lifting the bezel.  Go around very carefully and "generally" a gap will form.  Then you a case knife.  It is scary...unless it is a junker.
I use a safety razor as littlewatchshop explained above.
Uncase the movement before you start on the rim to reduce the risk of damage to the dial in case of mishap.
Good luck
Thank you "Littlewatchshop" & "Nucejoe" for your recommendations on the process and what to use.
Yes, I started the process off using a Single Edge Razor Blade (very carefully) which helped a bit but soon found out that I needed something with a better grip / handle on it and well used my fancy customized (has my initials on it) box cutter to follow up on the process.
That did it for me and was successful to remove it.
Live and learn.
I just wish that there had been an easier way to this process or at least a specific tool to use.
Here is a picture of the type of basic straight edge razor that I used to start the process followed up along with my customized box cutter to actually complete the process.
1371821022_PremiumLockingBoxCutterUtilityKnife.thumb.jpeg.ac7c8509da866c220fb4c7a4db0449a3.jpeg154205577_PremiumLockingBoxCutterUtilityKnifeii.thumb.jpeg.ed9b13ab88f2babe4529d3cbe53c1d8a.jpeg
 There are watch repair tools you just can't work without,  on which you should spend the  budget you have considered,  in a case like this alternative approach works, so we save.
22 hours ago, Klassiker said:
Thanks Klassiker for your post.
Yes that particular tool probably or just maybe would have or could have done the job. Though that tool is designed specifically to remove a watch Bezel.
I can see an individual who is a watch repair enthusiast, spending that kind of money $ specifically just for that tool.
As for myself, well yes I wouldn't mine having one but for the price money wise $ I just cannot justify spending that amount of money $ specifically for a tool like that since I am not a watch repair enthusiast...just an individual wanting to fix just one watch.
I needed to remove the watch crystal with a sort of slight downward curved bezel like rim attached to it (if you look closely at the picture I posted of it).
Maybe that tool would have done the job...maybe not.
Though the more I look at that specific tool the more I think that just maybe it would have done the job.
Too bad that specific tool is so expensive....it's reasons such as that, that I had to take an improvised approach to my specific situation.
Edited by Orhorolgy
@Orhorolgy
Apologies, I didn't mean to be flippant or condescending, but it wasm't a serious recommendation. In fact I don't have one of those tools either, as there are better ways to spend money if it is just a hobby. It's kind of a running joke on here, that you can never have enough tools.
The way you removed the bezel, beginning with a razorblade, as recommended by Littlewatchshop and Nucejoe, is a perfectly legitimate method, certainly not a bodge, and the way that most of us would proceed.
Klassiker......no apologies are necessary. Like all the previous post in this thread, I believe that your intentions in your suggestion are sincere, genuine and acceptable. So please, again, no apologies for just trying to help out. I really appreciate it.
It's all good! 🖕
Also, yes you are also correct about "one never having enough tools" (joke or not).
By the way after reading your first post about that specific tool I started to do a search for it or something similar to it and well I happened to find this?
https://www.vevor.com/products/watch-bezel-removal-opening-repair-tool-52mm-max-effortless-repair-machine?variant=31444090093666&utm_source=criteo&utm_medium=US
Edited by Orhorolgy
Well all thanks to you sir! 👏
What really got my attention on it was the price. It seems very reasonable. I just don't know if it is a knock-off duplicate and is it really worth the price?
Now, for it's asking price, that is something that I wouldn't mind having or adding to my small tool collection. It would definitely come in handy to support my small watch collection (which is like 35-40 watches).
Edited by Orhorolgy
That same tool is sold on a well known Chinese site for only half the price.
I always use a stanley knife in same way as the razorblade methode mentioned above.
Edited by Tony13
type error
Hi  When working on watches there are many things get your goat, removing backs and bezels and re fitting them as some are very hard to get back on. Pictured below as a few of the required tools. As always there are cheaper and ones that function well for the occasional user Case op1 will remove bezels and backs and can be had for around the £30 mark. A supplier of the chinese copies Is Ali Express an bit like the Chinese amazon. Hope you find this info useful         cheers
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
