Hi everyone, new member here. I just picked up my first training watch, it has as Raketa 2609HA movement in it. I disassembled it, cleaned it, and now the hard part, I'm trying to put it back together 😀. I have my barrel and train of wheels installed and I just put in the pallet fork.
I thought I'd try to see if it would snap back and forth when I put a small amount of wind in the barrel, but the pallet fork doesn't stop at the ends. The movement just starts running until there is no more power.
Is this normal in some watches or do I have an alignment problem maybe? I've reinstalled the pallet fork 2-3 times now and it seems to be seated right.
I've attached a short video, thanks so much for your help!
This is normally a sign that the stones or at least one stone is seated too far into the fork. Rather than an escape tooth falling on the locking face of the fork it falls on the impulse face, then the other impulse face and you have this result.
Thanks nickelsilver! Your explanation seems sound to me, sounds like a problem I won't be able to solve anytime soon though. I've tried to take 2 pictures of the pallet on both extremes of it's movement, could you check if these confirm your idea?
Fluttering might happen due to bent fork, excessinve side shake on fork arbour,  banking pin issues,    can't it.
@JohnR Is proper escapement possible here?  what do you expect to see with balance installed.
 I worked on a case like this,  oscialtion seemed normal, but would flutter once I removed the balance.
TIA for your advice
Actually there's several questions to be asked of like what was the watch doing before it was disassembled did the watch run? In other words this is the way it came it was in the running condition?
while the above statement is true there's also a problem with it? I've seen exactly what is shown and there was no problem at all with the escapement at least when the balance wheel was in the watch ran. For whatever reason it's just bouncing off the impulse planes of the stones my suggestion to put the balance wheel in to see if it runs. One of the problems that happens when you manually push on the fork it's not the same as the impact from the balance wheel is considerably slower. So this means in this particular case it doesn't go all the way weren't supposed to be fast enough and it bounces off the impulse planes. It doesn't necessarily mean the escapement is set perfectly but in my past experience putting the balance wheel in the watch ran problem solves even if it's not exactly ideal but it's still run seven runs who cares which is why I suggested putting the balance wheel in seeing of that solve the problem.
It's also why asked if the watch was running in the first place the pallet stones normally don't move themselves in the cleaning process the fork can get bent of somebody is careless. But that's probably not what's happening it's probably not a bent fork it's probably the way the watch was made in the first place as bizarre as it is
Almost posted the above. I won't duplicate, but I'll add a bit of context with some alternate imagery/application (usually helps me remember things).
Another of my proclivities includes woodworking; specifically luthiery (stringed instrument making, with archtop guitars being my weapon of choice). Shellac is a component of many wood finishes. Specifically for my use, a French polish, where it's the only component and mostly process. I haven't made any up in a while, and it's not at all an exact science, but I usually try to guess how much I'm going to need for a project (it doesn't keep long, and any leftovers are wasted), and pour enough shellac flakes into a little squeeze bottle, then pour in just enough booze to cover, and some for me should I feel like it. Which I never do, because Everclear is gross but I mention this because the potability of it is not at all shared with petroleum distillates and helps with the alternate framing. Shake, wait, and repeat every few hours until it's all dissolved. Takes a solid day to get the flakes fully dissolved.
Re: OP, my first thought was pallet jewel depthing, but bouncing hadn't occurred to me. It seems like an easy way to test between the two would be to hold the pallet to one side or the other, give the mainspring a little wind, then let go and see if it'll hold. If the jewels are deep enough, the escape wheel tooth should be on the locking face and not the impulse face, and it won't go anywhere without the balance (or your tweezer tips) to give it a nudge. Do both sides, since either could be too deep, and would be able to kick the whole thing off on its own with the other jewel getting a bounce to keep the it going. If it'll hold when held to start on both sides, it's probably fine and just a function of where the fork was when you initially gave it some wind. If not on both or either, it's the jewels in the pallet fork.
Rather than running straight over to the high diving board and attempting to reset the pallet jewels, you might consider dredging up a donor movement. I don't know how common that particular movement is, but Russian watches tend to be plentiful in my 404 hunts, so possibly an inexpensive option. Pallet jewels don't get messed with often, so the odds of getting a good fork seem pretty high.
Edited by spectre6000
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
