NH35 Hairspring problem
Manxcat
I am new to watch repair, I apologize for getting any details wrong.
I bought an Invicta off eBay advertised as not working that has a NH35A in it.  The symptom was that you could wind all day and it would never start ticking or become wound at all.  I assumed there was a barrel/arbor/mainspring problem and pulled that out.  The mainspring was not engaged with the arbor...but there was no reason...I twisted the arbor and it garbed the spring just fine.  I got to thinking there may be a problem in the train so I was going to pull the balance and the pallet level and when I pulled the balance bridge, the balance wheel stayed in the watch...have not seen that before.
I got out my staking tool which I am not well practiced with, removed the hairspring from the balance bridge, got it restaked on the balance shaft, when to get it mounted to the balance bridge again, and it fell off the balance shaft.  There does not seem to be an adjustment cut in this spring collet.  I know you cant put anything on there (such as glue or thread lock) because it needs to be adjustable, but there is no tension to the shaft.
Any idea why it would just fall off?  I dont think anyone else messed with this previously...but that is a possibility too...it is from eBay.
you took out the balance cock and you just pulled out the HS from the balance? Weird! I suppose it was messed with before.
You could try tightening the collet, using your staking tool, but most likely there is another problem in there...
my 2 cents: get a new balance complete from ebay  - you should be able to find one for NH35
If there is no adjustment cut in the collet, then it wasn't build to be adjustable.
Nucejoe, I dont think it was...but I was not expecting that.  The NH35 is a very widely used movement...didnt imaging the hairspring would just fall off the shaft.
Matabog, without a cut, I had not thought about it much farther...but I suppose I could use a riveting tool to push the metal toward the shaft...might try that.  I am going to order balance, probably a whole movement...but I still wanted to try to fix this one just because.
Thanks for the feedback!
10 hours ago, Manxcat said:
I am new to watch Repair
As you're new to watch repair you need to learn that you should expect the unexpected.
Then typically the hairspring does not fall off. This is where we really need a picture to see how it fell off.
I've also attached the technical bulletin just in case you didn't have one
Then for something like this a balance complete is what you need it be the easiest and the best. But you may find that the balance complete conceivably cost more than the whole movement so it's probably just a movement complete.
NH35_TG.pdf
NH35 has stud carrier ( beat adjustor) arm, so the need for collet adjustability is redundant so far as beat adjustment.
Setting the collet about where it was would negligably affect dynamic poise of the oscilator and is not a concern in this case.
So I would glue/peen ... etc   the collet in this case, since as JohnR said you are probably looking at purchase of another movement complete.
Regs
10 hours ago, matabog said:
My 2 cents: get a new balance complete from ebay  - you should be able to find one for NH35
The issue is that the cheap ones are iffy and have a poor reputation, and an original one is maybe 10 Euro less than a complete new mov.t.
I dealt with these Seiko balances a while back, but due to my own failings rather than whatever mystery befell this particular balance. I was 100% only concerned with learning, and didn't really care all that much about the watch itself. In freedom bucks, as I recall (this was not in the current pandemic economic paradigm) the balance was $20 plus shipping (purchased along with a bunch of other stuff from Cousins as I recall), and a complete movement was available to my door for $35 from Ali-X. I went the balance route because I didn't think I wanted another movement just kicking around, I wanted to fix rather than replace, etc. Knowing what I know now, I'd have just gotten the movement. The extra $7, or whatever it would have worked out to after distributing the shipping, isn't enough to worry about, and the spare screws and such come in handy (at least the way I do things).
In your case, it might actually serve yet more utility. Fixing this balance for the purpose of learning obviously has value EXCEPT that this is not the sort of balance you're likely to come into contact with otherwise that might benefit from fixing. It's not the sort of balance that's intended to be fixed (I'm 99.999% sure you can't even buy a balance/hairspring separately unless someone is out there splitting them for some reason on eBay or something), and trying to fix it is not going to teach you how to attach hairsprings to balances so much as how to potentially undo whatever freak accident this particular balance fell victim to that the collective hive mind here has never seen before. The lesson just isn't really all that applicable to anything in the real world, and thus not really worth the brain damage to learn. Sometimes the answer really is to just replace the parts with new (especially when they're as cheap and readily available as these are). I think the old timers would say you then stash the old away for down the road when the parts aren't available anymore, at which point you'll have enough experience to roll your eyes at past you and this weird thing, fix it, replace whatever balance needs replacing at the time, and not think twice about it.
Spectre6000, I agree, but I had purchased a staking tool and this was my first chance to try to use it...it did end badly but I learned alot from it.  New parts on the way, specifically a whole movement.  I may circle back to this movement, pickup a balance and hairspring which seem to only be available together which I do see as a good thing and see if there is actually more wrong with this movement that I have not even found yet.
I am not in this to make money or even save money...I like keeping myself busy with things I feel contribute.  Fixing a watch or learning how feels better than a video game or watching a TV show.  I have not been doing this long, I have made many mistakes already and will make many more.  My mistake this time was picking a stake that was too big...the collet got stuck inside it...lesson learned.  I though it was close to the shaft size and didnt want to damage the staff
I think the biggest thing I have learned so far in watch repair is that there are no shortcuts at all.  Not with processes, not with parts, and not with tools.  Thanks to all for the feedback!
Jdm you mean there are cheap chinese parts to NH35 too.  How to tell the diference?
If you buy from a reputable seller, and the part is promised as genuine, so should be. In my opinion when it's about this class of watches it's about not wasting money paying more to get less. Even if it's small money.
    • Hi can someone tell me where a can buy this chart for breguet hairspring frequency?
    • OK Rich, may be You are just a little bit more worried than really needed. Who am I to say, jus a newbie here but... Such a big forum will not collapse in any case, exept if the people loose their interest to participate. If something happens to the owner,  then senior members will be able to handle the forum. Let me show an example where one of the moderators of the russian forum (thow He was not russian), a man of great knowlage abd big heart, passed away in 2023. Thow His personal site is still working, the russians coppied the whole site to safe place here. I mean, all depends on the people and if they need to do something, they will find the way. Actually, the forum is place where people can meet and share. As a final measure, people can share their phone numbers and use Viber to comunicate, at least people who are interested to keep connection between each other.
    • Since I couldn't slow the machine down enough for my liking, I started off slowly with a higher grit.  I began (very lightly) with 1000 grit paper: https://www.amazon.com/gp/product/B07DTJBND1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Finished with 3000 grit: https://www.amazon.com/gp/product/B07DTFSMT1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Afterwards I went on to polish with traditional methods using felt & cotton wheels, with different grades of Dialux. Hope this helps.
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
